![]() | Home > Technical (L322) > Delayed Air Con |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Wow. 3.6 hours seems a lot. I assume it's a headache to get to it? 2010 4.4 TDV8 Vogue SE |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2654 ![]() ![]() |
https://www.aulro.com/afvb/l322-range-rove...put-2.html
So, just to confirm, these sticky valves are actually in the compressor or is it a separate unit?
Yes, the valve is in the rear of the compressor. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
kooky_guy,
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
Not driven mine for 3 months and it's showing exactly these symptoms. I'll see if a bit more usage clears the sticky flaps. 2017 5.0 Autobiography Supercharged
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Thanks Nino. Very helpful pictures! 2010 4.4 TDV8 Vogue SE |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Are there any details of how to actually change this ?
John, search youtube for senden compressor valve removal, valve is held in place by snap ring -
I took a look at my compressor earlier, and was starting to think my compressor might be fecked.
LTB00693 documents the procedure but the only one that I can find is in either Japanese or Chinese. IIRC from when I saw the English version, the refrigerant has to be drained/collected before the valve is removed which would appear to mostly prevent it being a DIY task. |
I've just had my compressor replaced and it's completely fixed the issue, thank goodness.
Glad to hear its fixed |
