![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 354 ![]() ![]() ![]() |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2643 ![]() ![]() |
Not so plain to me - can you describe what difference you see please? |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
Going to check mine tomorrow. Parked the car up tonight and noticed a few wisps of smoke in the headlamps as i walked away and could smell hot oil so i guess it will be leaking |
Dogfishdave Member Since: 09 Feb 2016 Location: Bristol Posts: 76 ![]() ![]() ![]() |
I wondered what that smell was!!!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Just checked mine again |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Mine wasn't leaking when I checked it a couple of weeks ago, but I am still keen to find the correct size so I can get a supply ready for when it does leak. ( Ideally an old ring to take to the supplier I have found.) |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 ![]() ![]() ![]() |
Any update on part no's/sizes/material for the o rings please? |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I have replace my twice, first time I used black rubber O ring, well that lasted only 5000 mi, finally i found local shop that could
The previous owner of my car had to have the complete filter housing replaced under warranty due to an oil leak. It was a tiny crack in the casting which only showed when warm so he had already had the gasket changed twice previously due to the same leak. All good now |
I sure hope. my only needs new gaskets. they do look flattened and hard.we will see. |
DougBLC Member Since: 23 Jul 2016 Location: Barton-Le-Clay Posts: 6 ![]() ![]() ![]() |
Black stains on the driveway, then a sniff of burning oil, a quick look underneath, oil everywhere, so will check the pipe as discussed here. Did we ever substantiate the ring sealing toroidals dimensions??
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
There may be a delay whilst everyone frantically scours the house for a dictionary |
O rings I used are ID 9.00mm x 1.8mm |
