Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 4 of 38 <123 45 ... 363738>
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Just looged on -
You can clearly see a DIFFERENCE between the OE seals ( pic above & the part I have purchased ) and the New V2 seals - its as plain as day
I would suggest to anyone on this thread - USE the V2 version unit - there is a reason why LR has modified this pipe - there's always more to this than you might think
IS IT WORTH TAKING THE RISK - with O rings that we don't know too much about - drive along and its leaking !!!!!!
Point made Thumbs Up
Post #372162 13th Feb 2016 1:31pm
GraemeS
Not so plain to me - can you describe what difference you see please?
Post #372211 13th Feb 2016 8:13pm
Baltic Blue
No one has reported the correct size O ring, but I am going to inspect mine this weekend to check for any signs of a leak because I am booked in for a service/MOT the following week and it will be my last chance to get any wok done under the LR Approved warranty.
I have bought a£40 endoscope off eBay so will hopefully be able to take pictures. I have found a local supplier of Viton O rings but need an old ring to take to get measured.
Has anyone got one?
Post #392648 22nd Jun 2016 1:59pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Going to check mine tomorrow. Parked the car up tonight and noticed a few wisps of smoke in the headlamps as i walked away and could smell hot oil so i guess it will be leaking Rolling Eyes
Paul Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #397859 26th Jul 2016 10:28pm
Dogfishdave
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
I wondered what that smell was!!!
Just checked mine and it is leaking. Did anyone ever find out the correct size O ring
Many thanks Dave
Post #398107 28th Jul 2016 5:51pm
Just checked mine again Whistle
All still good Very Happy Very Happy There is nothing that can't be fixed with a hammer😜😜
Post #398136 28th Jul 2016 7:53pm
Baltic Blue
Mine wasn't leaking when I checked it a couple of weeks ago, but I am still keen to find the correct size so I can get a supply ready for when it does leak. ( Ideally an old ring to take to the supplier I have found.)
Post #398147 28th Jul 2016 8:28pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Any update on part no's/sizes/material for the o rings please?
Post #402817 31st Aug 2016 9:08pm
nino_nino
I have replace my twice, first time I used black rubber O ring, well that lasted only 5000 mi, finally i found local shop that could
make Viton O rings and so far they are holding. However , i have leak at oil cooler itself, i took the cooler apart i have ordered two gaskets from Dan. Hopefully that will fix the leak. O rings I used are 9.00x1.80 mm.
Post #402915 1st Sep 2016 3:51pm
marsie
The previous owner of my car had to have the complete filter housing replaced under warranty due to an oil leak. It was a tiny crack in the casting which only showed when warm so he had already had the gasket changed twice previously due to the same leak. All good now Thumbs Up Paul
Post #402932 1st Sep 2016 6:24pm
nino_nino
I sure hope. my only needs new gaskets. they do look flattened and hard.we will see.
Post #402948 1st Sep 2016 7:23pm
DougBLC
United Kingdom 2011 Range Rover Vogue SE TDV8 Zambezi Silver
Black stains on the driveway, then a sniff of burning oil, a quick look underneath, oil everywhere, so will check the pipe as discussed here. Did we ever substantiate the ring sealing toroidals dimensions??
thanks
Doug
Post #403858 7th Sep 2016 12:25pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
There may be a delay whilst everyone frantically scours the house for a dictionary Wink Rolling with laughter
Post #403863 7th Sep 2016 12:36pm
nino_nino
O rings I used are ID 9.00mm x 1.8mm
Post #403864 7th Sep 2016 12:37pm
DougBLC
Thumbs Up n_n - did you get Viton versions?
Toroidals? did some engineering many moons ago..!
Post #403876 7th Sep 2016 1:47pm
