Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
13th Feb 2016 1:31pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2529 |
Not so plain to me - can you describe what difference you see please? |
13th Feb 2016 8:13pm |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 |
Going to check mine tomorrow. Parked the car up tonight and noticed a few wisps of smoke in the headlamps as i walked away and could smell hot oil so i guess it will be leaking
26th Jul 2016 10:28pm |
Dogfishdave Member Since: 09 Feb 2016 Location: Bristol Posts: 76 |
I wondered what that smell was!!!
28th Jul 2016 5:51pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
Just checked mine again
28th Jul 2016 7:53pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3780 |
Mine wasn't leaking when I checked it a couple of weeks ago, but I am still keen to find the correct size so I can get a supply ready for when it does leak. ( Ideally an old ring to take to the supplier I have found.) |
28th Jul 2016 8:28pm |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 |
Any update on part no's/sizes/material for the o rings please? |
31st Aug 2016 9:08pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
I have replace my twice, first time I used black rubber O ring, well that lasted only 5000 mi, finally i found local shop that could
1st Sep 2016 3:51pm |
The previous owner of my car had to have the complete filter housing replaced under warranty due to an oil leak. It was a tiny crack in the casting which only showed when warm so he had already had the gasket changed twice previously due to the same leak. All good now Paul
1st Sep 2016 6:24pm |
I sure hope. my only needs new gaskets. they do look flattened and hard.we will see. |
1st Sep 2016 7:23pm |
DougBLC Member Since: 23 Jul 2016 Location: Barton-Le-Clay Posts: 6 |
Black stains on the driveway, then a sniff of burning oil, a quick look underneath, oil everywhere, so will check the pipe as discussed here. Did we ever substantiate the ring sealing toroidals dimensions??
7th Sep 2016 12:25pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
There may be a delay whilst everyone frantically scours the house for a dictionary |
7th Sep 2016 12:36pm |
O rings I used are ID 9.00mm x 1.8mm |
7th Sep 2016 12:37pm |
n_n - did you get Viton versions?
7th Sep 2016 1:47pm |
