Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android
Page 9 of 36 <123 ... 8910 ... 343536>
Dave1946
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Thanks for the help Paul.
I'll give that a try in the morning and report back.
The Rangy is tucked up and asleep now. Lol
In the file browser should it show up as camera?
Dave
Post #290067 31st Oct 2014 9:30pm
hex
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
should look like this pic
you should see USB1 or USB2 depending where you have plugged it in
Post #290070 31st Oct 2014 9:40pm
hex
some new splash screens
few others to play with
if I get time I will do a few animated ones as well Smile
Post #290130 1st Nov 2014 11:25am
mjdronfield
Looking good
The last 2 are my favs...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #290137 1st Nov 2014 12:28pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
It seems to stick out quite far at the bottom compared to mine do you have to cut the holder down more to get flush?
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #290140 1st Nov 2014 12:43pm
hex
Its not fully in so I can remove it to work on it
And its a different unit should be for a BMW
Post #290141 1st Nov 2014 12:55pm
Dave1946
Well I've found out that the USB sockets on my head unit are fine!
The trouble I was having with feeding music into one was because I'd put some stuff onto a SD card and put that into a USB card reader which I plugged into the USB socket. It was a trial run job and of course was doomed from the start, because the read speed of the card reader couldn't match that of the head unit. Except that I didn't realise that until I'd had all the problems.
Once I got my brain in gear and thought about it I put the same music onto a pen drive, and hey presto, it works fine!
As for the camera. Well, that's a different story.
It seems from lots of reading on line that USB webcams will not, as a general rule, work with Android, period.
There are some apps available that purport to allowing a webcam to work on a phone or tablet, AS A WEBCAM, but make the point that 'this app can't cooperate with other Android apps'. So not going to work with DVR apps.
So it would seem that the Erisin camera has been developed especially by them to work with their head units. Although their advertising suggests otherwise.
Someone else may know different to this, in which case please let me know, as my forth attempt at communication with Erisin has again met with failure.
I'm now looking at trying a convential reversing camera, feeding it with the required voltage from an outside source, and putting it's video feed into the appropriate pins in a USB plug.
Dave
Post #290156 1st Nov 2014 5:03pm
hex
this is the web cam I used
http://www.ebay.co.uk/itm/261432809268?_tr...EBIDX%3AIT
and I also got this to give me a wider view angle
http://www.ebay.co.uk/itm/400532087555?_tr...EBIDX%3AIT
Post #290162 1st Nov 2014 5:39pm
Dave1946
We'll knock me down with a feather!!
All the twaddle I've just spouted and you have an ordinary one working ok Paul!
That takes me right back to why then doesn't mine recognise the cam I bought from PC world?
And how come after reading everywhere that webcams won't work with Android - they do!
Dave crawls under a stone!
Post #290164 1st Nov 2014 5:56pm
hex
the thing to remember is that the android part is one of many components on this unit, all of which is interfaced to a master control unit that provides all the non android items such as DVD player or the revers cam inputs audio and video outputs and inputs are switched as needed by the MCU. The MCU is hierarchically speaking above Android
Android itself and the hardware it's made to run on does not natively handle , Sound Controls: Balance, Fader, Audio levels, Video controls Aux input, rearview camera with separate switching, DVD etc. Steering wheel controls and Canbus interface Front face buttons/knobs and illumination I-pod interfacing etc .
That's why this is a custom build of android and there are a lot of "Native Apps" that use the android interface to drive the MCU and the sub components
Included in the build are some generic USB drivers so most things will work ok but it is very basic support , you may find that the cam from PC world has sound autofocus etc. that wont work so in this case the cheap and cheerful device will be much better.
paul
Post #290166 1st Nov 2014 6:31pm
Dave1946
Whewwww thank the Lord all sorted now.
The camera I'd bought ( PC World £14:99) is working ok. Although it isn't showing up on the 'car record' software pre installed in the head unit, I thought it worth just installing Daily Roads voyager to see what happened, and there it is!
So I'm all done now.
Thank you to the guys who kindly helped me.
Next thing is to sell all the old units, which will hopefully fund the fitting of an amp and active crossovers for the sound system 🙉
Dave
Post #290184 1st Nov 2014 8:14pm
comports
This has turned out to be a very interesting thread...
I tried a while ago with another Erisin unit. plugged in and it worked (keeping all my old gear in the car) but the sound was not great and it was very slow. I guess the units have come a long way since then though.
I'm very tempted to go for it but wanted to check a couple of questions.
I've had the stage 2 amp upgrade from our friend Baris and now my stock unit sounds really great - it would be a shame to lose this now. Has anyone found a way to get the new unit to correctly use the dap to drive the speakers without massive re wiring.? I see talk of aux outputs if the amp has aux in (which I could ask Baris to do for me). Would that then be plug and go..?
Has anyone got DAB through the unit or will the DTV (bought at the same time) tune into DAB stations..?
Has anyone kept the old head unit but swapped it out for the RR Midi unit (which I guess performs the same functions but is smaller to fit in the love box better)..?
Thanks all in advance.. Ash
2016 SDV8 AB
Post #290220 2nd Nov 2014 8:48am
Dave1946
Going back to the adapter that you got Paul, to give you a wider field of view, how is that fitted to the camera?
It looks as though there is a threaded fitting into which the lens screws. If that's the case how does that attach to the camera?
This morning I'm fitting the camera into the car and I find that it does have quite a narrow field of view, so perhaps one of those wide angle adapters would be a good idea, although I'm not sure if it will fit the camera.
Post #290247 2nd Nov 2014 11:24am
Dave1946
This is the camera I'm using.
Post #290249 2nd Nov 2014 11:25am
Dave1946
Will I ever get the hang of pictures on forums!
Post #290251 2nd Nov 2014 11:26am
