Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs?
Page 5 of 22 <123 456 ... 202122>
mjdronfield
Here is a pic of the boxes my bulbs came in. Shows make etc ;
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #257908 6th May 2014 2:53pm
psgk
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Thank you mjdronfield,
I'll have another look at mine at the weekend when I have more time. I may have to buy another set if I've damaged these ones significantly.
No problem with the senior moment, I have them all the time and it did remind me to add some vehicle details to my signature which I should have done when I joined the forum.
I'll be very interested in hearing how you get on GraemeC Peter Kemp
Chelmsford
UNITED KINGDOM
Range Rover Vogue MY2002 4.4l V8
Java Black
Charcoal Trim / Oxford Seats
Colour Coded: Door Handles, All Badging Front and Rear, Bonnet Vent, Foam A-Bar / Nudge Bar
Range Rover Style 11 20'' Wheels
US Spec Front Sidelight / Indicator Light Units / Rear Light Units (MY2005 Style)
Retro Fit Sony / Alpine RES
Various LED Light upgraded Interior / Exterior
Lower Rear Tailgate Gas Strut modification
Post #257909 6th May 2014 3:00pm
psgk
Yes, the boxes and info are identical to those I received. If my bulbs didn't have that small nib at the top of the glass envelope left when they are manufactured they would fit as I think that couple of extra mm would make all the difference.
Really do need to improve the reversing lights as wonderful Essex County Council now turn off all our street lighting at midnight, so trying to reverse into my drive, which is a tight fit anyway if I get home late is a bit of a gamble.
I've already taken out a O/S Rear Light Unit and that was in broad daylight!
A reversing camera has been on the "to do " list for some time. Peter Kemp
Chelmsford
UNITED KINGDOM
Java Black
Post #257911 6th May 2014 3:13pm
trickymickey
United Kingdom 2002 Range Rover HSE 4.4 V8 Adriatic Blue
Glad to tell you all brightness of reverse lights is not an issue as they are not part of the MOT !. Same as front fogs .
Post #257964 6th May 2014 9:20pm
GraemeC
Tried to fit mine last night and failed. The problem is the upgrade bulbs have offset pins at approx. ten to two position, compared to the original bulbs which have the pins opposite each other (quarter to three position)
From doing a bit of reading, this is intentional on the part of the manufacturers to help ensure people use the correct bulbs for the correct functions.
This page shows has a diagram of the offset pins for a 433D BAY9 bulb
http://www.phoenixautobulbs.co.uk/pr/halogen-433d-12v-21w-bay9s/
I may send mine back if I can be bothered.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #258053 7th May 2014 3:08pm
this might help if you order replacements,
Post #258057 7th May 2014 3:33pm
mjdronfield
So this may explain why some have issues ? Do the later cars use straight pins perhaps ?
Just looked at the bulbs I took out, and they had offset pins ;
Which is why I only had a potential length issue (Steady !!)
I seem to remember reading that the holder could accept either type......could be wrong....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #258066 7th May 2014 4:32pm
pld118
Could you not file the lower mounted of the bayonet pins down with a file so as to get round the pin offset problems but still leaving the upper bayonet pin unscathed to ensure a good fit (did that with LED bulbs and it worked perfectly well)?
Post #258075 7th May 2014 5:38pm
@A11EXU, have you managed to do any daytime pics of your COBS? ... - .- -.
Post #258704 11th May 2014 9:01am
I received mine and like some mine will accept either type of bulb... I too had the length issue (ooh err) so i simply cut some material off the plastic locking pins on the side of the bulb holders using a craft knife. I then simply put an extra rubber "O" ring on to space the light back and hay presto Very Happy
Happy days Thumbs Up
Post #258709 11th May 2014 9:12am
RCusden
Wales
Very clever Craig Bow down
Post #258712 11th May 2014 9:19am
psgk
Hello Craig,
Very interested in your solution. I thought about using an additional rubber "O" ring but wasn't sure how that would help. Am I right in thinking that in paring a little material from the plastic projecting locking tabs each side of the bulb holder you are then able to twist the holder when fitting it to the back of the lens to give what in engineering terms is called I think, an interference fit or are you able to make it to fit as when using the standard sized bulb? Sorry,the brains not functioning to well this morning! Peter Kemp
Chelmsford
UNITED KINGDOM
Java Black
Post #258725 11th May 2014 10:42am
Taking a mm or 2 off the tabs mean your bulb will fit a mm or 2 further from the lens and you run less risk melting the lens Thumbs Up
Taking the material away in itself means you just have a poorly fitted bulb holder! Adding the extra "O" ring allows the bulb holder to lock in its original "designed way" but slightly further back Thumbs Up
The reason i decided to do it this way was two fold... Firstly i have explained, the second was because the 21w bulb was longer (in the metal holder, not in the glass section) so moving it back would put the filament closer to the original place...
Take any torch type light and move the bulb forward and back and you will notice the light get brighter & duller as the reflector does its job (in conjunction with the bulbs filament placement). Rear fog lamps that work on duel filament bulbs are a typical example. Put a side light bulb in a rear fog lamp and usually it will be brighter than a rear side lamp! Move that bulb a few mm forward or backward and the light dulls to match the usual side lamp strength. Hence why twin filament bulbs are usually staggered (also they usually mirror coat the reflector which makes it brighter still) but still the filament placement is critical for brightness Thumbs Up
This is why a lot of LED replacement bulbs don't do their job as the lamp you fit them too is filament orientation critical "if that makes sense?"
Hope that explains better? Thumbs Up
Post #258728 11th May 2014 11:19am
psgk
Many thanks Craig, an excellent explanation which is much appreciated. Peter Kemp
Chelmsford
UNITED KINGDOM
Java Black
Post #258730 11th May 2014 11:23am
Post #258733 11th May 2014 11:39am
