Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs?
Page 4 of 22 <123 45 ... 202122>
A11EXU
Location: Bishopton (Near the Big Muddy Field at Langbank) , SCOTLAND
Scotland 2004 Range Rover Vogue Td6 Adriatic Blue
This is after i realised that waiting til the weekend was Reverselightless with 2 gaping holes
So glue gun out and waiting to dry
If only the Glasgow rain would go into remission for 10 mins Big Cry
It is like not being able to sleep on Christmas Eve Shocked '54 Adriatic Blue Vogue
Post #257101 30th Apr 2014 8:49pm
let me know when you switch on Alex and i'll see if i can see them in swindon... Laughing ... - .- -.
Post #257105 30th Apr 2014 8:52pm
A11EXU
All done
Cool
Cool very bright
Can u see them Stan Thumbs Up '54 Adriatic Blue Vogue
Post #257114 30th Apr 2014 10:01pm
Thumbs Up Thumbs Up Thumbs Up
Post #257115 30th Apr 2014 10:16pm
A11EXU
Cool Cool I think i may just obtain a little bit of lens tinting vinyl
When i say bright i mean BRIGHT
Plus it might look better a little darker
If i am reversing and you are behind me - get yer Shades on cos my reverse lights will cut through your optic nerve and leave scarring on your windscreen Shocked '54 Adriatic Blue Vogue
Post #257126 30th Apr 2014 11:29pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Close encounters of the third kind Mr. Green 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #257132 1st May 2014 12:25am
mjdronfield
I take it you can see more from the drivers seat during the old reverse up a dark alley manoeuvre ?
Will you have to swap them out for mot or don't they look that obvious ?
Looks like it's worked though....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #257136 1st May 2014 5:29am
the whole sky lit up Alex.. Laughing
told you they would be bright Wink .....any chance of a day time pic... ... - .- -.
Post #257154 1st May 2014 7:57am
A11EXU
I will take daytime pick when i regain my vision
Can still see 12 wee squares burnt into my retina
MOT ?
Dont think there is any stipulation at all for brightness
But anyhow MOT'd last week - year to contemplate '54 Adriatic Blue Vogue
Post #257175 1st May 2014 9:35am
Welshdragon
Shocked
ouch I now have arc eye......all I see now is 2 white spots where ever I look..... Rolling with laughter If it dont work.......burn it!
Post #257189 1st May 2014 11:06am
psgk
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
Just tried to fit the 21watt halogen bulbs to my reversing light units on my MY2002 Vogue that mjdronfield obtained from Amazon.
Pins seem to be at a slightly different offset but got them into the holders. However when I tried to fit the bulb holders to the lens I found them too long to allow the holder to twist to secure in place and in attempting to do this saw that the plastic lens was being forced away from the back of the unit.
Did your bulbs holders twist easily mjdronfield or did you have to make any alterations to the bulb holder or lens unit.
I also must have shorted something out as the car would then not start and I had to jump start it using a spare battery
I wonder if the bulbs I received are slightly longer. I've had to revert to the original bulbs. Peter Kemp
Chelmsford
UNITED KINGDOM
Range Rover Vogue MY2002 4.4l V8
Java Black
Charcoal Trim / Oxford Seats
Colour Coded: Door Handles, All Badging Front and Rear, Bonnet Vent, Foam A-Bar / Nudge Bar
Range Rover Style 11 20'' Wheels
US Spec Front Sidelight / Indicator Light Units / Rear Light Units (MY2005 Style)
Retro Fit Sony / Alpine RES
Various LED Light upgraded Interior / Exterior
Lower Rear Tailgate Gas Strut modification
Post #257899 6th May 2014 1:47pm
mjdronfield
Well that's a bit pants.
Didn't make any changes to mine.
They were tight though - one bulb was easier to get into the holder than the other.
I think the bulbs have to be really in to their holder to allow the holder to twist into the lamp unit.
I pushed a but whilst turning and they fitted ok.
The pin offsets looked the same as what I took out. They will only go in in one position.
Interested to hear if anyone else has issues.
2 of us have managed to upgrade, and 1 has had to abort. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #257900 6th May 2014 1:55pm
psgk
Many thanks for the update mjdronfield,
The bulbs were a very tight fit in the holders. I pushed them well down to make sure they were seated properly.
Having got them in I couldn't get them out again and had too take a pair of pliers to them so I could replace the originals so I might have ruined both although the bulb glass is still intact
The reversing light units on my vehicle are bog standard MY2002 but I have upgraded the front sidelight / indicator and rear light units to US spec with the orange and red side running lights. The rear lens pattern is I think that of the MY2004 model with a clear lens above a red lens Peter Kemp
Chelmsford
UNITED KINGDOM
Java Black
Post #257901 6th May 2014 2:10pm
mjdronfield
I've not had to remove mine. Could be a bit tight then.
Sorry, I must have had a senior moment re the rear lights, as they obviously have nothing to do with the reverse lights.
I think I've got no more than 2 or 3 mm of the steel base of the bulb visible when it's in the black holder.......
Not sure if this helps. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #257903 6th May 2014 2:18pm
GraemeC
My Amazon bulbs arrived this morning - if I get chance to fit this evening I'll post up and let you know if I have any issues with them being longer or with the pin offset Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #257906 6th May 2014 2:31pm
