Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs?
Page 21 of 22 <123 ... 202122>
mjdronfield
I had some upgraded halogen ones on my TD6 that just fitted in....but the heat melted through the plastic lens eventually.
It’s a tight fit. The group buy LED ones are fine if there are any left.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #486688 20th Aug 2018 8:54pm
dirtymonkey38
Autumn/Winter weather on the way, anyone want to do mine for me ha 2011 RR Autobiography 4.4 TDV8
Post #488422 8th Sep 2018 6:21pm
dirtymonkey38
miggit wrote:
A word of warning to you and others who have later cars with AGM batteries... the voltage of the car is 14.7 not 14.1 and this is too much for the those LED's Whistle I know, fitted them to a 2011 car and watched them go up in smoke, literally Shocked To get around this problem we installed some 12v regulator chips in the lights too (and some new LED panels Sad ) , and they didn't even get warm Very Happy
Can you tell me more about these regulator chips? how they are installed etc. I have a 2011 car with AGM battery, link to maplin obviously not available now they shut up shop so not sure what to be looking for. 2011 RR Autobiography 4.4 TDV8
Post #496977 28th Nov 2018 10:39pm
dirtymonkey38
Am I looking for buck converters? 2011 RR Autobiography 4.4 TDV8
Post #497077 29th Nov 2018 8:47pm
AJGalaxy2012
What wattage are the LED's ? Assuming theyre under 18w look for a 7812 regulator OR a 2.7v zener diode either will do it, the zener diode potentially easier install. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #497080 29th Nov 2018 9:01pm
dirtymonkey38
https://www.ebay.co.uk/itm/2x-COB-6W-LED-W...2749.l2649
2 in each lamp when they arrive so 12w in each. straight forward to hook up? 2011 RR Autobiography 4.4 TDV8
Post #497085 29th Nov 2018 9:31pm
AJGalaxy2012
Either circuit will do it, the 7812 choose one rated at 1.5amps or more, for the zener diode, choose the voltage and it will reduce the incoming voltage by that amount eg a 2.7v zener diode with 14.8v coming into it, the output will be 14.8 - 2.7 = 12.1v. You may not be able to get the exact voltage you want eg they may be 2.0, 2.7, 3.3 etc. BMW i3 Electric Car
Post #497104 30th Nov 2018 6:11am
dirtymonkey38
Thanks AJ. I guess the 7812 would be the better option. Not had a look at the wiring yet but do you know if it would it be one 7812 chip per light unit or just the one on the loom? 2011 RR Autobiography 4.4 TDV8
Post #497153 30th Nov 2018 4:59pm
you are all making a mountain out of a molehill.....
the cob panels are compatible with AGM batteries ..my cob panels have been ok on my 2012 with an AGM battery fitted for a few years now..
Post #497157 30th Nov 2018 5:35pm
FrankN
Germany 2004 Range Rover Vogue Td6 Bonatti Grey
I have another reverse lamp version build
its like near original
So slowly I'm working
The back lights on it, my problem: at night that is not very nice and the dark rear window looks good during the day, at night shortages had the Rückfahrwarner schonmal gepippstmal, because a black car is parked on the other side of the street, ok, was a little fast Cool
Now it should be lighter!
Cree LED
[URL="http://abload.de/image.php?img=s-l200_003iwjuu.jpg"][/URL]
but since the LEDs are too long for our lamp, I have unceremoniously extended the socket
[URL="http://abload.de/image.php?img=img_8729u8j9m.jpg"]
just the right plastic tube to extend, found in the electrical box.[/URL]
[URL="http://abload.de/image.php?img=img_87277wkpt.jpg"][/URL]
The plastic is welded to the soldering pistons, ready to go and the first test in half dimming
[URL="http://abload.de/image.php?img=img_8731mnq0h.jpg"][/URL]
Best regards
Frank
Post #497315 2nd Dec 2018 12:21pm
please edit your post to english frank..
Post #497316 2nd Dec 2018 12:35pm
FrankN
Hi Stan , I will make with translator the next minutes
Post #497320 2nd Dec 2018 12:51pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Fellas, stop messing around with cob panel conversions and fiddling with bulbs that are too long.
The bulbs that I specced and Bushy30 now sells are a straight fit and also brighter than the cob panels.
They are a no brainer. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #497321 2nd Dec 2018 12:54pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #497328 2nd Dec 2018 2:02pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
I'd agree with Grofus. His/Bushy's replacement bulbs are perfect. 2010 4.4 TDV8 Vogue SE
Post #497525 4th Dec 2018 8:00am
