Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs?
Page 3 of 22 <123 4 ... 202122>
mjdronfield
Looking forward to seeing the results of that then.
Just had confirmation that my amazon link above is for 2 bulbs and they have been dispatched........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #255566 22nd Apr 2014 1:33pm
Flashman
Any news on if the bulbs work? Tom
Current Drive
Previous Drives
Post #256791 28th Apr 2014 10:05pm
mjdronfield
Yes, sorry, not been out in the dark yet.........
They are a little bit longer than standard bulbs and just fit.
I took a before picture in January when I was trying to get led bulbs in. Will try and get the car in the same place later and do an after pic.
Look brighter visually though, which is a good start.
2 bulbs were received using the amazon link I posted earlier. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #256806 29th Apr 2014 5:23am
Flashman
Nice one, fingers crossed for the light test. Tom
Current Drive
Previous Drives
Post #256822 29th Apr 2014 7:56am
mjdronfield
Here are my pics with the bulbs from the above amazon link fitted ;
http://www.amazon.co.uk/433d-H6W-OSP-Halog...ds=h6w+21w
Before
After
Not sure the camera does them justice.
There were about 4 months between the pics, so it could be a spot the difference.......
Going from two 6w to two 21w for less than £8 is not bad in my book.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #256934 29th Apr 2014 8:27pm
might be a good idea to keep an eye on the lenses just to make sure the bulbs dont get to hot and melt them.. ... - .- -.
Post #256936 29th Apr 2014 9:00pm
mjdronfield
Good point Stan.
By definition, the bulbs are closer to the lenses and will generate more heat than the standard ones.
Figured they won't be on for that long at a time...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #256940 29th Apr 2014 9:23pm
true, reversing will only take around 10 seconds or so ,so heat build up should be minimal.. ... - .- -.
Post #256964 30th Apr 2014 7:02am
Flashman
Nice one. I agree that heat build up risk should not be an issue. I will order a set too. Tom
Current Drive
Previous Drives
Post #256970 30th Apr 2014 8:02am
A11EXU
Location: Bishopton (Near the Big Muddy Field at Langbank) , SCOTLAND
Scotland 2004 Range Rover Vogue Td6 Adriatic Blue
Received these :
Modifying reverse lamps to take them:
Used this :
Less than 1 minute
Just need to wait til i get home to insert them
One or two in each lamp Rolling Eyes
Sitting waiting to pick one of my daughters up from Taekwondo and couldn't resist the challenge '54 Adriatic Blue Vogue
Post #257054 30th Apr 2014 6:39pm
A11EXU
Reply to my own post
Deffo go with 2
Stay quite near Glasgow Airport dont want any Malaysian Airlines mistaking my Tailgate for a runway
(No offence meant Embarassed )
Only thing after that is a little tinting film to darken down the back end
Pictures to follow - weekend job if i can wait Thumbs Up '54 Adriatic Blue Vogue
Post #257058 30th Apr 2014 6:47pm
those COB leds will be very bright!!! ... - .- -.
Post #257059 30th Apr 2014 6:47pm
mjdronfield
So you are making it brighter so you can tint it darker ?
Seriously though, will that setup give you the same amount of light as the standard bulbs, after you tint the lights, if you see what I mean ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #257061 30th Apr 2014 6:55pm
Similar point to above... I looked at my reverse lights in the dark the other night and they work like a headlight... I.e. the bulb reflects off the reflector... Your LED's would need to be 10x brighter than the originals as they do not use the reflectors... Ill be very interested to see how yours work Thumbs Up
Post #257075 30th Apr 2014 7:40pm
i have some red COB leds Craig and trust me they are very bright... ... - .- -.
Post #257091 30th Apr 2014 8:27pm
