Home > Technical (L322) > Adaptive Dynamics Fault light
Page 1 of 10 12345678910>
funnyguy1
United States
Adaptive Dynamics fault light just came on and terrain response doesn't light up. Any tricks to clearing this? Thx! Mike
Post #234209 12th Jan 2014 2:19am
adigorn
fix front shocks wiring Thumbs Up
Post #234211 12th Jan 2014 5:43am
funnyguy1
United States
Is that something I can do or does it have to go to to the dealer??
Post #234314 12th Jan 2014 5:10pm
adigorn
Its connecting two wires together so hope you can manage Wink
look for the broken wire in the area of metal covers on the top of front suspension struts (under the bonnet)
(you can undo the 2 torx and remove covers for access)
When fixed the fault will clear Thumbs Up
Post #234338 12th Jan 2014 6:59pm
funnyguy1
United States
That is exactly what it was!! Thank you so much, saved me a 7 hour round trip to the dealer. The 2nd wire was almost broken
as well so I spliced that as well! Excellent instructions too! Mike
Post #234411 13th Jan 2014 12:46am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
When I had this problem the LR assistance guy said there was going to be a recall, still waiting.
Ian
Post #234471 13th Jan 2014 11:33am
minkius
my light came on a week ago. I took it to dealer and they said right wheel sensor needs replacing. Its booked in to do this Thursday. However after seeing this thread I popped the bonnet open and voila a broken cable, attached a piece of wire and taped it for now as I will still have it replaced on Thursday but at least I get a better ride until Thursday Thumbs Up
Post #234526 13th Jan 2014 4:08pm
Jmattbdl
United States 2011 Range Rover Supercharged 5.0 SC V8 Rimini Red
Thanks, My 2011 RR had display of Adaptive Dynamic Fault also. I just followed advice about checking shock wire & bingo. It was easy to see wire was broken. Was an extremely simple fix! Terrain Response now is operational.
Post #243951 21st Feb 2014 4:33am
Got the same fault today Sad but cannot see any broken wire Sad All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #245581 1st Mar 2014 9:45am
adigorn
did u have a good look (and gentle pull)
Post #245606 1st Mar 2014 1:22pm
Jmattbdl
Pop the hood & look at the shock towers on the right and left side. There are two white wires or maybe there in a harness running into the shock towers. Remove the two star screws from the bonnet and pull up on the plug very slowly follow the wires down to the shock check both sides. My problem was just where the wire exits the bonnet or just inside. I've attached a photo you can see I've taped the wires with electrical tape when I was done but you need to take the two screws off and look inside that cap.
Post #245611 1st Mar 2014 1:58pm
i saw it - i opened it - but i am scared to brake more when removing the harness... Sad guess i bring the car to the local dealer by monday just 1,5 miles away from where i live Wink All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #245630 1st Mar 2014 3:24pm
T24RES
No pics Jmattbdl Big Cry Ian
Post #245646 1st Mar 2014 6:25pm
there is now. Thumbs Up
Post #245649 1st Mar 2014 6:41pm
Jmattbdl
Just a simple soldering job. If it's too far down the shock tower it's difficult to repair. Mine was at the top, a very simple repair. At least you know the problem and it should be an inexpensive fix. Before I investigated the problem the dealer had no idea what the problem was they said just bring it in we need to put it on the diagnostic machine first total BS. You could twist them together for a temporary fix until you take it to the dealer. Good luck. Let me know what they charge you to fix it.
Post #245652 1st Mar 2014 7:16pm
