Home > Technical (L322) > Adaptive Dynamics Fault light
Page 8 of 10 <12345678910>
DrRob
Right being driver's side if sat in car I assume? Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560468 7th Jul 2020 11:19am
Weegie
If it is RHD. Very Happy John
GAP iiD BT-Sold
Post #560470 7th Jul 2020 11:26am
GGDR
paulbrown22 wrote:
I know Greg and others have posted fancier repairs...
Cheers Paul - and my nuclear option repair, necessary because five or maybe more soldering repairs told me the cable had to go - is here:
https://www.fullfatrr.com/forum/topic54413.html
...and I might add has been absolutely faultless.
. Cheers, Greg
Post #560488 7th Jul 2020 1:08pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Thanks Greg, good to know it's lasted - I've been admiring your setup and browsing Ebay since last night!
I'll order up some bits so I have them ready just in case/when it goes again - from what you say it's highly likely to reoccur, the existing wire certainly wasn't very flexible anymore, and I don't like waiting if I know there's a problem lurking there, even what seems to be a fairly minor one...
Post #560561 7th Jul 2020 10:06pm
EK
United Kingdom 2009 Range Rover Vogue TDV8 Barolo Black
First, I would just like to say thanks for all the information I have learned from this site and wish I had the knowledge to contribute. Maybe one day, but for now I'm a noob.
I also have the same issue detailed in this thread. "Adaptive Dynamics Fault". It was intermittent for a couple of days, but now remains on constantly.
I was planning on fixing the issue using the information provided but stopped when checking the condition of the wires going into the top unit. The insulation on the wires has indeed been cracked but the copper wire beneath appears not to be damaged. It also looks like my car (2009 Vogue) has the updated wiring? See pics.
I didn't want to go ahead and cut through the wires when they didn't appear to be broken. Would the fact that the outer insulation is split warrant this?
I have attached pics to show the damage. I don't have access to any IID tool or the likes.
Hopefully someone can advise me on the way forward. Or a trip to my local indy tomorrow may be in order.
Regards
Will
Post #564042 9th Aug 2020 5:08pm
GGDR
Will have a look at my repair, very easy with a few bits off ebay:
The factory copper wire, and the insulation are both very brittle. Your fault may be related to the rear dampers however, looking at the state of your wires, the fronts are almost certainly broken, even though they look like the copper is not broken.
I'd bet money there is a break in the wire somewhere, either the new section, or in the old section even though you can't see it (yet)
. Cheers, Greg
Post #564043 9th Aug 2020 5:16pm
EK
I'm reading it now Greg. Looks like an excellent and inexpensive job you have made of it. Do you think that will be my issue looking at the wires in the pics I provided?
Thanks for the quick reply
Will
Post #564044 9th Aug 2020 5:21pm
GGDR
yes and a further look at your pics i can see a new revised wire has been spliced in. However, following the wire from the damper, there are two crimps. Undo all the tape around the original loom wire after the crimps. You may find a break here.
But your new section is damaged too so I think it's got to be re-done.
I undid as much of the old wire as possible and fitted the plug connectors n the point where they branched off the loom. If you do this all that tape would have to come off anyway. I've no idea why land rover used tape here.
An IIDTool will tell you which one is causing the fault but if you don't have an IID then just unwind the tape and have a really good look.
. Cheers, Greg
Post #564045 9th Aug 2020 5:26pm
EK
Going to give it a go shortly. Might be a bit of a bodge until the parts you listed turn up in the mail.
I will post back either way.
Thanks Greg Very Happy
Post #564047 9th Aug 2020 6:19pm
EK
No joy I'm afraid. I checked along the length of both cables as best I could.
I couldn't find any damage other than what's shown in the pictures I posted.
So cut through the damaged portion used a butt connector to join and was met with the same error message. Big Cry
I'm stumped. Other than a trip to my local indy is there anything else I'm missing?
What about the rear ones? Do they ever fail?
Thanks
Will
Post #564060 9th Aug 2020 8:30pm
mjdronfield
I’ve read a few posts about those failing, but the wiring doesn’t have to turn with the strut like the front ones, so not as common.
Worth a check.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #564064 9th Aug 2020 9:27pm
paulbrown22
I know we're in COVID times, but if there's no obvious damage then the quickest way to at least narrow down which of the 4 corners is your problem would be to get the fault codes read, whether at a garage or someone local with an IID or other suitable tool. Presumably to just read the fault codes a much cheaper code reader would suffice, and still very handy to have if you don't want/have a full on (expensive) IID type tool.
Post #564252 11th Aug 2020 9:33pm
neilly
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
I had the adaptive dynamics fault appear on the dash, read it with diagnostics.
Was the rear offside height sensor. Changed and now all good.
Thanks
Post #564326 12th Aug 2020 3:48pm
EK
All fixed now by a local garage.
Turned out to be the front offside ride height sensor. Thumbs Up
Post #564616 14th Aug 2020 11:47pm
DrRob
I’ve popped my cherry on this! Bling it went! IID out. Right front (drivers). Wire had parted from clearly a previous solder job. Turret off, wires stripped and soldered. Cleared fault. Sorted Thumbs Up
Will order LR looms and sort soon Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #564662 15th Aug 2020 3:13pm
