Home > Technical (L322) > Adaptive Dynamics Fault light |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
What about the rear ones? Do they ever fail?
16th Aug 2020 10:22pm |
EK Member Since: 09 Aug 2020 Location: Scotland Posts: 7 |
Mine turned out to be a rear ride height sensor. |
25th Mar 2021 10:23am |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 |
Just had the dreaded “Adaptive Dynamics” message. Gap iid is saying ADCM- Active Damping
22nd Nov 2021 12:16am |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
I cant remember the exact wording but almost every L322 needs those wires changed now.
22nd Nov 2021 12:29am |
The wires have been replaced with later type lead. Really want to know if anyone else has same error message on Gap iid. |
22nd Nov 2021 2:16pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
I had this issue this weekend checked the front wires all good. So scanned the car turned out to be the right rear. when i exposed the wires all looked good but the right rear plug had not been pushed home fully it just came out when i pulled it (I did not have the squeeze the tabs to release it) i pushed it back in until it clicked, cleared the fault and boom all working well again and a nice plush ride again. 2012 Vogue 4.4 TDV8 - Current
3rd May 2022 7:34am |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 757 |
Mine must be one of the last to suffer this! I'd disturbed the strut-top cables in the boot when hoovering and the next time I went out I got the 'bong'. The front cables are the newer style (due to a late build) so I guessed it was the rear. Sure enough, one of them was broken right at the point of entry into the plug.
27th Feb 2023 7:47am |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 179 |
Just fixed mine the near side wires had been repaired before but had broken in a different place, a bit of solder and a heat shrink sleeve sorted that. will order some new bit of wiring harness (LR032839) to fix it properly when things warm up a bit as all the wires are breaking up.
30th Nov 2023 10:11am |
Red Desert Member Since: 15 Apr 2012 Location: Lake Constance Posts: 20 |
7th Feb 2024 4:38pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2504 |
Did you fit the proper dual-track sensors with both the height and CVD outputs or copies that only have the height outputs? |
7th Feb 2024 8:14pm |
Fitted LR original parts from the dealer (6 pins) |
7th Feb 2024 8:29pm |
Bear2010 Member Since: 26 May 2024 Location: Stratford-upon-Avon Posts: 1 |
Hi All,
26th May 2024 4:17pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8287 |
Needs code reading, waste of time and money guessing a fault...!! Pete
26th May 2024 4:45pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7818 |
I’d agree with Pete, but add that Adaptive dynamics fault relates to the CVD dampers / wires but Suspension fault tends to relate to air suspension… height / air / sensors, so 2 different systems, though working together….
26th May 2024 4:49pm |
