Home > Technical (L322) > Adaptive Dynamics Fault light
Page 3 of 10 <12345678910>
Seabass
Sweden
Had the same problem, now solved thanks to this site Thumbs Up 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Swedish LR club member #5333
Post #253385 8th Apr 2014 8:57pm
rocksteadyeddie
Top tip thread. Same issue here on my 2010 FFRR 5.0. 20 minutes later after a bit of cack handed soldering job-jobbed.
Thanks guys Thumbs Up
Post #274320 4th Aug 2014 9:12pm
Thumbs Up All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #274353 5th Aug 2014 8:06am
Q86ARR
2015 Range Rover Autobiography 5.0 SC V8 Havana
Land Rover technical bulletin LTB00416v3 covers this fault.
A wiring overlay is available with a modified boot\grommet to prevent the fault reoccurring.
The part number is LR032839
It is recommended that both wires are replaced at the same time
The bulletin lists a totL labour time of 0.2 hours.
Post #274409 5th Aug 2014 1:33pm
Andy B
Just had the same on mine, fixed in 30 mins with some soldering and re-taping. Thanks to all for the invaluable advice! Thumbs Up Thumbs Up Thumbs Up Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #287313 18th Oct 2014 1:48pm
MARKS2RR
England 2010 Range Rover Vogue 4.4 V8 Santorini Black
Same fault here. soldered and tape it, job done.
wish all faults were that easy. Thumbs Up
Post #290611 4th Nov 2014 1:55pm
cliffc
United Kingdom 2012 Range Rover Autobiography TDV8 Zermatt Silver
Had the same problem on my 2011 TDV8 this week. Solved in 10 minutes thanks to this forum Thumbs Up
Post #295758 28th Nov 2014 8:52pm
Java Jungle
Monaco 2011 Range Rover Autobiography 4.4 V8 Nara Bronze
Same thing here yesterday...problem solved in 10 minutes!!! Thumbs Up
Thanks guys!
JJ
Post #296878 3rd Dec 2014 10:54pm
Andy B
Same thing happened again last week and the original wire has snapped at the point it enters the rubber grommet at the top of the strut. Bit the bullet and got a replacement part (LR Part LR032839). Piece of pee to fit and all done in 15 mins. And they have improved the quality of the wire significantly. By the way the kit comes with crimp connectors for joining to the old loom.
Just waiting for the other side to go now! Laughing SDV8 AB MY 2019
Post #298602 12th Dec 2014 3:52pm
Quixotic
United States 2010 Range Rover Supercharged 5.0 SC V8 Alaska White
anyone know of a module or fuse for the adaptive dynamics in a 2010 RR SC? I eliminated the intermittent fault about 6 months ago by replacing the wires to the shock towers however after 2 weekends of heavy wheeling the dynamics fault is back and is constant. I checked wires and seem okay. any help here is appreciated. BTW this photo is from the 2015 SCARR rally and it was a blast.
Post #324805 28th Apr 2015 4:13pm
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Just had mine go too Big Cry
10 mins with soldering iron under the bonnet and all sorted Very Happy
Will get the replacement parts from Dan the man shortly.
Bow down Thumbs Up
Post #326575 7th May 2015 7:28pm
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Just had the same problem with mine.
Many thanks to the forum members for your info on how to resolve the problem. Thumbs Up
Appreciated. Thumbs Up Thumbs Up
Post #331664 9th Jun 2015 3:30pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Me too
Post #334929 28th Jun 2015 8:18pm
just had a look at mine and they have fitted the updated parts to the 2012, the wires coming into the rubber grommets aren't wrapped in tape, they are a thicker rubber cable. so hopefully this won't be a problem Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #334931 28th Jun 2015 8:31pm
wealy
What a poor design.
I've just looked at the same area on my jag (which has dynamic ) and its the same?
Come on land rover - sort this out!
My advice to everyone is fix this before it breaks - because it will eventually!
Post #334941 28th Jun 2015 10:41pm
