Home > Technical (L322) > Adaptive Dynamics Fault light |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
fix front shocks wiring |
12th Jan 2014 4:43am |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 383 |
Is that something I can do or does it have to go to to the dealer?? |
12th Jan 2014 4:10pm |
Its connecting two wires together so hope you can manage
12th Jan 2014 5:59pm |
That is exactly what it was!! Thank you so much, saved me a 7 hour round trip to the dealer. The 2nd wire was almost broken
12th Jan 2014 11:46pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
When I had this problem the LR assistance guy said there was going to be a recall, still waiting.
13th Jan 2014 10:33am |
minkius Member Since: 11 Feb 2013 Location: Essex Posts: 17 |
my light came on a week ago. I took it to dealer and they said right wheel sensor needs replacing. Its booked in to do this Thursday. However after seeing this thread I popped the bonnet open and voila a broken cable, attached a piece of wire and taped it for now as I will still have it replaced on Thursday but at least I get a better ride until Thursday |
13th Jan 2014 3:08pm |
Jmattbdl Member Since: 21 Feb 2014 Location: Ohio Posts: 5 |
Thanks, My 2011 RR had display of Adaptive Dynamic Fault also. I just followed advice about checking shock wire & bingo. It was easy to see wire was broken. Was an extremely simple fix! Terrain Response now is operational. |
21st Feb 2014 3:33am |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 |
Got the same fault today but cannot see any broken wire All my spelling errorz are belong to me!
1st Mar 2014 8:45am |
did u have a good look (and gentle pull) |
1st Mar 2014 12:22pm |
Pop the hood & look at the shock towers on the right and left side. There are two white wires or maybe there in a harness running into the shock towers. Remove the two star screws from the bonnet and pull up on the plug very slowly follow the wires down to the shock check both sides. My problem was just where the wire exits the bonnet or just inside. I've attached a photo you can see I've taped the wires with electrical tape when I was done but you need to take the two screws off and look inside that cap.
1st Mar 2014 12:58pm |
i saw it - i opened it - but i am scared to brake more when removing the harness... guess i bring the car to the local dealer by monday just 1,5 miles away from where i live All my spelling errorz are belong to me!
1st Mar 2014 2:24pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
No pics Jmattbdl Ian |
1st Mar 2014 5:25pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
there is now. |
1st Mar 2014 5:41pm |
Just a simple soldering job. If it's too far down the shock tower it's difficult to repair. Mine was at the top, a very simple repair. At least you know the problem and it should be an inexpensive fix. Before I investigated the problem the dealer had no idea what the problem was they said just bring it in we need to put it on the diagnostic machine first total BS. You could twist them together for a temporary fix until you take it to the dealer. Good luck. Let me know what they charge you to fix it. |
1st Mar 2014 6:16pm |
