![]() | Home > Technical (L322) > Adaptive Dynamics Fault light |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
What about the rear ones? Do they ever fail?
EK Member Since: 09 Aug 2020 Location: Scotland Posts: 7 ![]() ![]() ![]() |
Mine turned out to be a rear ride height sensor. |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Just had the dreaded “Adaptive Dynamics” message. Gap iid is saying ADCM- Active Damping
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
I cant remember the exact wording but almost every L322 needs those wires changed now.
The wires have been replaced with later type lead. Really want to know if anyone else has same error message on Gap iid. |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
I had this issue this weekend checked the front wires all good. So scanned the car turned out to be the right rear. when i exposed the wires all looked good but the right rear plug had not been pushed home fully it just came out when i pulled it (I did not have the squeeze the tabs to release it) i pushed it back in until it clicked, cleared the fault and boom all working well again and a nice plush ride again. |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 778 ![]() ![]() ![]() |
Mine must be one of the last to suffer this! I'd disturbed the strut-top cables in the boot when hoovering and the next time I went out I got the 'bong'. The front cables are the newer style (due to a late build) so I guessed it was the rear. Sure enough, one of them was broken right at the point of entry into the plug.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 191 ![]() ![]() ![]() |
Just fixed mine the near side wires had been repaired before but had broken in a different place, a bit of solder and a heat shrink sleeve sorted that. will order some new bit of wiring harness (LR032839) to fix it properly when things warm up a bit as all the wires are breaking up.
Red Desert Member Since: 15 Apr 2012 Location: Lake Constance Posts: 20 ![]() ![]() |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Did you fit the proper dual-track sensors with both the height and CVD outputs or copies that only have the height outputs? |
Fitted LR original parts from the dealer (6 pins) |
Bear2010 Member Since: 26 May 2024 Location: Stratford-upon-Avon Posts: 1 ![]() ![]() ![]() |
Hi All,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8402 ![]() ![]() ![]() |
Needs code reading, waste of time and money guessing a fault...!! Pete
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
I’d agree with Pete, but add that Adaptive dynamics fault relates to the CVD dampers / wires but Suspension fault tends to relate to air suspension… height / air / sensors, so 2 different systems, though working together….
