Home > Technical (L322) > Adaptive Dynamics Fault light
Page 9 of 10 <12345678910>
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
What about the rear ones? Do they ever fail?
Thanks
Will[/quote]
Yes, I had one go on mine. Went in same way just next to where it entered the plug.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #564782 16th Aug 2020 11:22pm
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
I've just had this error message, so a job for the weekend.
Greg's mod looks awesome.
Those of us with VX220s / Elises will shudder as we think of the ABS sensor wires which fail in the same way...
Post #588843 25th Mar 2021 11:18am
EK
United Kingdom 2009 Range Rover Vogue TDV8 Barolo Black
Mine turned out to be a rear ride height sensor.
Post #588845 25th Mar 2021 11:23am
Sonearly
Just had the dreaded “Adaptive Dynamics” message. Gap iid is saying ADCM- Active Damping
U3000-04 (AE) Control Module - General Failure information - system internal failure. It is intermittent, can clear fault and it may come back immediately or last for 100 miles. My question is, have any others had the same fault code and it has been damaged wiring. Or alternatively has the only option been to replace module.
Post #613378 22nd Nov 2021 1:16am
Range Rover L322
I cant remember the exact wording but almost every L322 needs those wires changed now.
Mine was pretty much the last 2012 AB off the production line, is very low mileage and the wires front and back were very brittle. Definitely worth upgrading and highly likely to fix it permanently.
Post #613380 22nd Nov 2021 1:29am
Sonearly
The wires have been replaced with later type lead. Really want to know if anyone else has same error message on Gap iid.
Post #613414 22nd Nov 2021 3:16pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
I had this issue this weekend checked the front wires all good. So scanned the car turned out to be the right rear. when i exposed the wires all looked good but the right rear plug had not been pushed home fully it just came out when i pulled it (I did not have the squeeze the tabs to release it) i pushed it back in until it clicked, cleared the fault and boom all working well again and a nice plush ride again. Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #630486 3rd May 2022 8:34am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Mine must be one of the last to suffer this! I'd disturbed the strut-top cables in the boot when hoovering and the next time I went out I got the 'bong'. The front cables are the newer style (due to a late build) so I guessed it was the rear. Sure enough, one of them was broken right at the point of entry into the plug.
GAP tool told me it was the rear left and upon inspection, I was concerned that there wasn't enough wire showing to effect a repair. Managed to clean a tiny amount of wire and set about with a load of solder. Next, I filled the plug with clear glue. It's a temporary repair, but it's worked and the fault has been cleared.
 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #657949 27th Feb 2023 8:47am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Just fixed mine the near side wires had been repaired before but had broken in a different place, a bit of solder and a heat shrink sleeve sorted that. will order some new bit of wiring harness (LR032839) to fix it properly when things warm up a bit as all the wires are breaking up.
Where would I be without this forum.. Bow down Thumbs Up
Post #679116 30th Nov 2023 11:11am
Red Desert
Germany
The gap tool says all four height sensors are installed incorrectly or have a mechanical error. So all four sensors were replaced, calibrated and errors deleted. Wiring, fuses etc. checked. I can do whatever I want, the four sensors are still shown as faulty. I suspect an error in the module. But maybe someone else has an idea where I can look
Post #684972 7th Feb 2024 5:38pm
GraemeS
Australia
Did you fit the proper dual-track sensors with both the height and CVD outputs or copies that only have the height outputs?
Post #685001 7th Feb 2024 9:14pm
Red Desert
Germany
Fitted LR original parts from the dealer (6 pins)
Post #685008 7th Feb 2024 9:29pm
Bear2010
Adaptive dynamics fault
Hi All,
First Post as a new member. Adaptive dynamics fault has appeared on my 2012 westminster. Checked all 4 corners and wires are perfect, like new. Unfortunately, I don't have an iid so wanted to ask if this could be a different fault?
It started intermittent and now is constant and on longer journeys comes up with "suspension fault".
All thoughts welcome 👍
Thanks
Post #693366 26th May 2024 5:17pm
Needs code reading, waste of time and money guessing a fault...!! Pete
Post #693368 26th May 2024 5:45pm
mjdronfield
I’d agree with Pete, but add that Adaptive dynamics fault relates to the CVD dampers / wires but Suspension fault tends to relate to air suspension… height / air / sensors, so 2 different systems, though working together….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #693369 26th May 2024 5:49pm
