Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification
Page 9 of 13 <123 ... 8910 111213>
steptoe
Have you tried using one of these http://www.maplin.co.uk/automotive-current-tester-217879
Identifies the circuit draining your car battery
Available for mini or maxi fuses
Provides an easy-to-read LCD display of the circuit's performance
Simply plugs into standard blade type fuse holder
Post #170539 6th Feb 2013 5:37pm
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
No, i did'nt. But I've done many drain tests from the earth on the battery, seeing no drain.
Would this tool see a drain on the fuse in this case?
Also, to test it I guess I'd have to lock myself in the car for half an hour and then begin the tests (not a prob given the time already wasted). 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #170540 6th Feb 2013 5:55pm
steptoe
Yes, it has a fuse plug which you plug in in place of the fuse and it measures and shows in the LCD display any current flowing through the fuse holder.
Post #170542 6th Feb 2013 6:15pm
Ibartsimp
I get the overall functionning but why would I see a drain in the fuses I don't see (with all fuses in) when testing the drain from battery -ve to earth jump stud? 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #170543 6th Feb 2013 6:19pm
Useful little device, I use one. Thumbs Up
You need the maxi version to fit the standard size fuses in a RR.
You don't need to shut yourself in the car to use it, just lay it on the passenger seat whilst connected to a fuse and then you can shut the car, wait for it to go to sleep and then read the display thro the side window.
Post #170547 6th Feb 2013 6:24pm
Ibartsimp
yes but to test the fuses individually one after the other I need to be in the car and do the swaps, but that's anecdotic. real question is above.
Post #170548 6th Feb 2013 6:27pm
You wouldn't.
It's just another way of measuring the same thing.
Post #170549 6th Feb 2013 6:37pm
Ibartsimp
Now I agree Wink I still have to see a constant drain after the car's been locked for 30 mins, then that's a great investigation tool (I've seen equivalents that can be linked to the ohmmeter). 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #170552 6th Feb 2013 6:45pm
Ibartsimp
Well I still have a drain, even with fuses 22 & 49 and venture cam off
Went from 12.55 to 11.8 in 24 hours Sad
Will indeed try an inside the car test on fuses... 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #170836 7th Feb 2013 8:13pm
You're not having a lot of luck.
Couple of things I would do.
Disconnect the red feed cable to the rear fuse board and leave disconnected and see what happens to the battery.
This means all the bits served from the rear fuseboard will be disconnected instead of removing fuses individually.
Be careful when you remove the cable it will have 12V on it so don't touch anything with the end.
Also wrap the end of the cable with cloth or similar to stop it touching anything overnight.
Second, remove the glove box light bulb and the 3 loadspace light bulbs and leave out overnight just to see if you happen to have a faulty light switch causing lights you can't see to come on.
I'm now running out of ideas fast. Smile
Post #170895 8th Feb 2013 9:43am
Ibartsimp
Well, let's say I have one f.. hard drain to locate. The rest is fine and I'm very pleased to discover that I have a venture cam.
Now if I could have a reliable car, things would even be better Wink
I'm not sure to understand where the
is. In the engine bay, inside the car and if so, where? 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #170899 8th Feb 2013 10:13am
In the rear loadspace side compartment, opposite side to radio etc.
Disconnect the large red wire in the centre of the picture.
And be careful with it. Thumbs Up
Post #170901 8th Feb 2013 10:23am
adesmith
England 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I have the same issue and will try this tonight. The easiest tell for me as to if the battery has drained is that the screen takes a few mins to come on after startup.
Post #170913 8th Feb 2013 11:02am
Ibartsimp
Ok, I had not detailed look at this part. Now a few questions arise, as usual Wink
1. I suppose it's the lead you"re talking about. Will I still be able to open (and close) the load area once removed (with the remote key for instance)
2,3,4 & 5. What are these pending plugs? Still trying to understand why my car has the SatNav menu and if these bits are related...
Last, why haven't you asked me to mess with the fuses in this area of the car?
Put a link to the image since I made it huge (detailed) on purpose
Post #170914 8th Feb 2013 11:02am
Sorry you are correct, if you remove the cable you won't be able to lock or possibly open the tailgate.
I thought all the central locking was fused at the front of the car which appears not to be the case.
Although as removing the cable from the fuseboard means it won't lock presumably you could still open it.
Never mentioned the rear fuseboard before as you still have about another 50 fuses to work thro on front fuse board. Smile
Number 1 on picture is cable to remove if you wish to, the alternative is pulling fuses individually.
If you wish to remove fuses I will check which fuse serves the tailgate locks.
Number 2 is supply to tow bar sockets.
Numbers 3,4 and 5 no idea what they are for.
Post #170920 8th Feb 2013 11:31am
