Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack
Page 3 of 10 <12345678910>
supershuttle
you can actually file the top down so its flat, that's what I did before welding the rectangle on the pressure is then not delivered via the "horns" Shocked Geoff
Post #208350 5th Sep 2013 7:27pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Another one purchased Smile
57cm lift is way more than others I was comparing to
+ jacking adaptor naturally Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #210616 16th Sep 2013 8:42pm
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
I got the ebay jacking adapter for this but it was resin rather than ali. Doesn't look like it will cope sitting on the bottle jack. Any one have any idea if you can get the ali jack adapter rather than the resin one?
Thanks.
Ian. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #217111 17th Oct 2013 2:55pm
http://www.ebay.co.uk/itm/BMW-MINI-JACK-AD...232885a6a2
Post #217115 17th Oct 2013 3:13pm
TurboTim
Steve
Were did you get the Alloy adaptor for the top of jack- or did you make it
Best regards
Tim- Worthing
Post #217118 17th Oct 2013 3:21pm
Errr.... Try the link in the post above. Thumbs Up
Post #217122 17th Oct 2013 3:56pm
Gruute
Belgium
I prefer a horizontal pumping jack. Much more easy to work with.
 2017 Range Rover Vogue TDV8 silicon silver
2011 Defender 90 2.4 TDCI Nara Exclusive
2008 Porsche 911 997 4S Black/black
1970 Porsche 911T 2.2 in restauration
1980 Toyota Land Cruiser BJ40 concours winner
Post #217387 18th Oct 2013 3:23pm
Andy
That looks like it would take your knuckles off!
Post #217437 18th Oct 2013 7:17pm
Gruute
Belgium
I doesn't hit the knuckles as you have just enough angle. It's not 100% horizontal.
And in most cases I put a wooden block under it. Surely no issue at than. 2017 Range Rover Vogue TDV8 silicon silver
Post #217781 20th Oct 2013 10:29pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
That horizontal pumping jack would be really useful with the deployable sidesteps. Where would I find one? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #217813 21st Oct 2013 8:53am
ianmacd
That looks like a silver coloured version of the composite ones I have but says its ali. Thanks. Current: RR L322 2010
Post #217885 21st Oct 2013 2:38pm
ebajema
The Merc jacks are also hydraulic pumping jacks. Modifying the top with the adaptor is just to introduce the load of the jack into the car in a better way Smile.
Which reminds me, still need to have my adaptor drilled for the top of the ram. MY 2010 5.0 SC Galway green and sand interior!!
Post #217886 21st Oct 2013 2:45pm
Gruute
Belgium
http://www.weberuk.com/ 2017 Range Rover Vogue TDV8 silicon silver
Post #217923 21st Oct 2013 6:47pm
Nomad
Thanks for that Gruute. I'll call them tomorrow. Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #217958 21st Oct 2013 9:28pm
Nomad
One more quick question: Does that Weber jack have enough lift to get a FFRR wheel off the ground: 385mm fully extended seems low? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #217970 21st Oct 2013 10:21pm
