Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 10 of 49 <123 ... 91011 ... 474849>
dont think it does miller, stating the obvious but having a clean windscreen helps or replacing the sensor might help.. ... - .- -.
Post #136860 20th Aug 2012 9:26am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Nav on Move and Lazy Lock
Hi guys, two questions.
1) My set up shows that Nav on the Move is on - However, apart from the home and memory destinations keys I am still unable to enter destinations once moving as all those buttons gray out. Is this something to do with having the 2010/11 Disc and software or am I missing something.
2) Again, although Lazy Lock is showing as on, I can't get the windows/sunroof to close automatically by pressing and holding the lock button - With my P38 this used to work and I'd also get a double beep if I superlocked and a window or sunroof was open - Any way of getting similar functionality with the iid - Got back into the car after dinner yesterday and realised I'd left the sunroof open Sad
Cheers African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #136861 20th Aug 2012 9:41am
have a read of the first few posts DE-RANGED.. Wink ... - .- -.
Post #136865 20th Aug 2012 9:57am
DeRanged Rover
Thanks Stan, Embarassed
Looks like we have the same problem with the Nav-On-the go ... did you ever find out what firmware others who have Nav on the go are running?
Any ideas re the Lazy Lock/Unlock feature? African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #136867 20th Aug 2012 10:10am
i suppose that the nav versions steve has quoted are the applicable ones that work, i dont think its worth the hassle to try and change the version tbh..
have you tried both the remote and door key options... ... - .- -.
Post #136869 20th Aug 2012 10:17am
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
@steve
Bump - my previous post on how to reset suspension.
Also, where do I navigate to find how long till next service?
Post #136901 20th Aug 2012 4:47pm
SteveMFr
Site Sponsor
Hi Lolo,
Sorry for the late reply.
I just want to make sure I understand what you mean by a 'reset': making an EAS system function again after it was disabled due to a fault? In this case the proper 'reset' would be to do a 'Clear Fault' on the EAS.
Re-enabling the EAS is only after the EAS has been disabled with the IIDTool - such as with a 'Deflate' function.
Disconnecting the battery won't help you much in either case, tho, so I am a little confused... Neutral
Regards,
Steve
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #136923 20th Aug 2012 9:08pm
SteveMFr
Site Sponsor
Please try again (and check the status when entering the menu).
Is it possible you are activating functions for one key only? And it's not your key?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #136925 20th Aug 2012 9:13pm
Lolo
My suspension kept going into emergency mode, so no lights at all, re enabling it on the iid gets it working again as does disconnecting the battery.
So that's grand I just thought when people were saying reset ur eas there was a specific option.
Can u help on my other question bout how to find out how long till nxt service?
I have a bit of work but want to wait till its getting a service unless it's ages away.. Thumbs Up
Post #136928 20th Aug 2012 9:35pm
Blackbird51
Hi all
For what its worth I would highly recommend that any RR owner get one of these. It is amazing how many items can be personalised and how many 'problems' can be solved using this bit of kit. Just brilliant Very Happy
Post #136934 20th Aug 2012 11:27pm
drakes
I have just had "susp in active" come up so plugged in the IIDT pressed the resume button but the tool does not appear. It was working fine a couple of weeks back when I did the V17 up date.
Any ideas.
Drakes 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #137016 21st Aug 2012 3:17pm
have you followed the correct procedure,
plug in unit
switch on engine
wait for the tool to show on the dash readout. ... - .- -.
Post #137019 21st Aug 2012 3:19pm
drakes
Yes Stan, I have done exactly the same as when I have used it before but this time nothing happens. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #137023 21st Aug 2012 3:29pm
all i can suggest is to reload the new firmware and try again, if that doesnt work then a pm to steve is in order... ... - .- -.
Post #137025 21st Aug 2012 3:36pm
spanner
Hi all
will this tool alter the height settings in so much as keep original ride height but alter access height for instance
Thanks
Post #137040 21st Aug 2012 4:50pm
