Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
dont think it does miller, stating the obvious but having a clean windscreen helps or replacing the sensor might help.. ... - .- -.
20th Aug 2012 9:26am |
have a read of the first few posts DE-RANGED.. ... - .- -.
20th Aug 2012 9:57am |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 |
Thanks Stan,
20th Aug 2012 10:10am |
i suppose that the nav versions steve has quoted are the applicable ones that work, i dont think its worth the hassle to try and change the version tbh..
20th Aug 2012 10:17am |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
@steve
20th Aug 2012 4:47pm |
Hi Lolo,
20th Aug 2012 9:08pm |
Please try again (and check the status when entering the menu). Is it possible you are activating functions for one key only? And it's not your key? RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
20th Aug 2012 9:13pm |
My suspension kept going into emergency mode, so no lights at all, re enabling it on the iid gets it working again as does disconnecting the battery.
20th Aug 2012 9:35pm |
Blackbird51 Member Since: 22 Sep 2011 Location: Portadown Posts: 39 |
Hi all
20th Aug 2012 11:27pm |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 370 |
I have just had "susp in active" come up so plugged in the IIDT pressed the resume button but the tool does not appear. It was working fine a couple of weeks back when I did the V17 up date.
21st Aug 2012 3:17pm |
have you followed the correct procedure,
21st Aug 2012 3:19pm |
Yes Stan, I have done exactly the same as when I have used it before but this time nothing happens. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
21st Aug 2012 3:29pm |
all i can suggest is to reload the new firmware and try again, if that doesnt work then a pm to steve is in order... ... - .- -.
21st Aug 2012 3:36pm |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 |
Hi all
21st Aug 2012 4:50pm |
