![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
dont think it does miller, stating the obvious but having a clean windscreen helps or replacing the sensor might help.. ... - .- -.
have a read of the first few posts DE-RANGED.. |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
Thanks Stan, |
i suppose that the nav versions steve has quoted are the applicable ones that work, i dont think its worth the hassle to try and change the version tbh..
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
@steve
Hi Lolo,
Please try again (and check the status when entering the menu). Is it possible you are activating functions for one key only? And it's not your key? ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
My suspension kept going into emergency mode, so no lights at all, re enabling it on the iid gets it working again as does disconnecting the battery.
Blackbird51 Member Since: 22 Sep 2011 Location: Portadown Posts: 39 ![]() ![]() ![]() |
Hi all
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
I have just had "susp in active" come up so plugged in the IIDT pressed the resume button but the tool does not appear. It was working fine a couple of weeks back when I did the V17 up date.
have you followed the correct procedure,
Yes Stan, I have done exactly the same as when I have used it before but this time nothing happens. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
all i can suggest is to reload the new firmware and try again, if that doesnt work then a pm to steve is in order... ... - .- -.
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 ![]() |
Hi all
