![]() | Home > My Range Rover > 5 RRs and I have to give up |
RRfranz Member Since: 25 Dec 2023 Location: Tirol Posts: 13 ![]() ![]() ![]() |
You are on the right path. I wish you every success. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
Hoping you are now on the right track Mariana... The geometry makes huge difference in feeling like a RR in my humble opinion... I often drive customer cars and they drive terribly! Suggest an alignment on a Hunter machine (we have one to use locally) spend time setting up correctly and the difference can be night & day!
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 718 ![]() ![]() |
Thanks RRfranz, my fingers are crossed.
Busy weekend but I've managed to replace the rusty, seized together parts.
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 223 ![]() ![]() |
Fingers crossed! 2012 Vogue TDV8 in Aintree green over sand |
Tracking/alignment now done and within specs |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 780 ![]() ![]() ![]() |
Can someone check this on their 06-09
Knares, on my Autel AP200 it's found under:
I've made a post in the technical section as I'd really like to get a comparison with someone else's car.
i have a GAP, i looked for the readings but i couldn't find anything to do with the power steering, i am sure it there some where RR 2005 4.4 petrol
I don't have an IID tool anymore but it should be under BCM/BPM similar to my Autel.
Okay, got fed up of getting nowhere so decided to break into one of the wires to the servotronic valve and measure current.
I then put my meter in series and attempted to measure the current: ![]() Here's the first result: ![]() I then thought maybe I had my meter setup incorrectly (probe connected to wrong port) So read The manual and tried again:
Then after double checking my connections: ![]() I believe this is 840ma? Is that about correct at idle? |
Admin, please could you move this thread to L322 technical?
