![]() | Home > My Range Rover > 5 RRs and I have to give up |
RRfranz Member Since: 25 Dec 2023 Location: Tirol Posts: 13 ![]() ![]() ![]() |
You are on the right path. I wish you every success. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Hoping you are now on the right track Mariana... The geometry makes huge difference in feeling like a RR in my humble opinion... I often drive customer cars and they drive terribly! Suggest an alignment on a Hunter machine (we have one to use locally) spend time setting up correctly and the difference can be night & day!
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 729 ![]() ![]() |
Thanks RRfranz, my fingers are crossed.
Busy weekend but I've managed to replace the rusty, seized together parts.
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 234 ![]() ![]() |
Fingers crossed! 2012 Vogue TDV8 in Aintree green over sand |
Tracking/alignment now done and within specs |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 784 ![]() ![]() ![]() |
Can someone check this on their 06-09
Knares, on my Autel AP200 it's found under:
I've made a post in the technical section as I'd really like to get a comparison with someone else's car.
i have a GAP, i looked for the readings but i couldn't find anything to do with the power steering, i am sure it there some where RR 2005 4.4 petrol
I don't have an IID tool anymore but it should be under BCM/BPM similar to my Autel.
Okay, got fed up of getting nowhere so decided to break into one of the wires to the servotronic valve and measure current.
Admin, please could you move this thread to L322 technical?
Picked up a very cheap (£15!) New, genuine rack to cooler return hose off eBay.
