Home > My Range Rover > 2012 Vogue TDV8
Page 10 of 10 <12345678910
pcourtney
toby - if you do find out that it's the ABS Control Module - I had mine reconditioned by Essex Recons down in Dagenham, it cost me £150 quid and every bit as good as I new one I believe Smile
https://www.essexrecons.com/shop/abs-units...r-service/
Post #711931 15th Feb 2025 10:03pm
toby1
Thanks. It cranks but does not fire, though it doesn't do anything with a flat battery Smile
I've had it suggested that a CTEK can't charge a flat battery and I may need a 'normal' charger. I am not sure but I will see if Lidl has anything on offer today. 2012 Vogue TDV8 in Aintree green over sand
Post #711957 16th Feb 2025 9:27am
toby1
A friend is lending me her charger tomorrow but i can't see what difference it will make.
The dash is flashing whilst connected to the charger so I have removed the negative lead to the battery.
Post #711980 16th Feb 2025 3:18pm
toby1
A friend loaned me this charger and I think the battery is taking charge. It has a handy bluetooth connection to an app for live data. It has not errored so far but I will give it a bit longer and connect the battery on Friday.
Post #712781 25th Feb 2025 7:00pm
toby1
In other news, the insurance renewal has come through: £486 up from £430 with esure. I tried the usual sites and the minimum elsewhere is £510. Direct Line declined to quote.
Hmm. Why on Earth is it so expensive? - it's not far off 10% of its overall value (if it was working, of course). FFS it's a 13-year-old car! 2012 Vogue TDV8 in Aintree green over sand
Post #712784 25th Feb 2025 7:15pm
lucasvrooij
Netherlands 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Nice one
Post #712790 25th Feb 2025 7:54pm
toby1
With the borrowed charger I have a lot more volts than the CTEK could achieve. I am grateful for the suggestion.
Today I decided to plug in the GAP tool after a few hours charge today. No flickering lights on the dash, at least, but some new codes. TBH, I am putting these down to low battery voltage still. The fuel pump error piqued my interest but alas, even this excellent forum does not return any result for the code when I searched.
I inquired about resetting this pump on a 405 post, but I do not even have the option in my GAP tool.
in any event I have decided to leave the poor weather and take a month in sunnier climes, so I will not be revisiting this until April, at the earliest. I am still undecided whether to renew the insurance due to this, but I probably will. Even an immobile L322 could catch fire, right? Smile
Post #712968 27th Feb 2025 9:03pm
toby1
One year of ownership today. I couldn't find any other company cheaper than esure so it renews today.
What I find surprising is this thread has over 20,000 views. I am still working from warmer climes and not back for a few weeks yet, but I'd be lying if I said the absence has made my heart grow more fondly for it. Smile
I'll have a go at most jobs that do not require a lift, but it's not knowing what's broken that is the most annoying part, especially as it ran before my grubby mitts started on it.
This forum is a great resource though and it is a massive help. There is one other thread with a similar-sounding issue but the poster has not returned for a few months with an outcome.
I'd like to declare 'it will run again!' but I am not taking anything for granted. 2012 Vogue TDV8 in Aintree green over sand
Post #714668 23rd Mar 2025 3:32pm
GraemeS
Australia
Your non-start issue only began after you changed the fuel pressure sensor and did something to its wiring. I would revisit that wiring. MY21.5 D350 Vogue SE Carpathian Grey
Post #715312 31st Mar 2025 10:39pm
toby1
And the upper HPFP pipe to the rail. I've been researching more elsewhere and in the W.M. and I think I am drawing up a structured plan to follow. To be continued... 2012 Vogue TDV8 in Aintree green over sand
Post #715319 1st Apr 2025 8:51am
