![]() | Home > My Range Rover > 2012 Vogue TDV8 |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 899 ![]() ![]() ![]() |
toby - if you do find out that it's the ABS Control Module - I had mine reconditioned by Essex Recons down in Dagenham, it cost me £150 quid and every bit as good as I new one I believe |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 224 ![]() ![]() |
A friend is lending me her charger tomorrow but i can't see what difference it will make.
A friend loaned me this charger and I think the battery is taking charge. It has a handy bluetooth connection to an app for live data. It has not errored so far but I will give it a bit longer and connect the battery on Friday.
In other news, the insurance renewal has come through: £486 up from £430 with esure. I tried the usual sites and the minimum elsewhere is £510. Direct Line declined to quote.
lucasvrooij Member Since: 10 Feb 2021 Location: Breda Posts: 4 ![]() ![]() ![]() |
Nice one |
With the borrowed charger I have a lot more volts than the CTEK could achieve. I am grateful for the suggestion.
One year of ownership today. I couldn't find any other company cheaper than esure so it renews today.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2639 ![]() ![]() |
Your non-start issue only began after you changed the fuel pressure sensor and did something to its wiring. I would revisit that wiring. MY21.5 D350 Vogue SE Carpathian Grey |
And the upper HPFP pipe to the rail. I've been researching more elsewhere and in the W.M. and I think I am drawing up a structured plan to follow. To be continued... 2012 Vogue TDV8 in Aintree green over sand |
