Home > My Range Rover > 2012 Vogue TDV8
Page 10 of 10 <12345678910
pcourtney
toby - if you do find out that it's the ABS Control Module - I had mine reconditioned by Essex Recons down in Dagenham, it cost me £150 quid and every bit as good as I new one I believe Smile
https://www.essexrecons.com/shop/abs-units...r-service/
Post #711931 15th Feb 2025 10:03pm
toby1
Thanks. It cranks but does not fire, though it doesn't do anything with a flat battery Smile
I've had it suggested that a CTEK can't charge a flat battery and I may need a 'normal' charger. I am not sure but I will see if Lidl has anything on offer today. 2012 Vogue TDV8 in Aintree green over sand
Post #711957 16th Feb 2025 9:27am
toby1
A friend is lending me her charger tomorrow but i can't see what difference it will make.
The dash is flashing whilst connected to the charger so I have removed the negative lead to the battery.
Post #711980 16th Feb 2025 3:18pm
toby1
A friend loaned me this charger and I think the battery is taking charge. It has a handy bluetooth connection to an app for live data. It has not errored so far but I will give it a bit longer and connect the battery on Friday.
Post #712781 25th Feb 2025 7:00pm
toby1
In other news, the insurance renewal has come through: £486 up from £430 with esure. I tried the usual sites and the minimum elsewhere is £510. Direct Line declined to quote.
Hmm. Why on Earth is it so expensive? - it's not far off 10% of its overall value (if it was working, of course). FFS it's a 13-year-old car! 2012 Vogue TDV8 in Aintree green over sand
Post #712784 25th Feb 2025 7:15pm
lucasvrooij
Netherlands 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Nice one
Post #712790 25th Feb 2025 7:54pm
toby1
With the borrowed charger I have a lot more volts than the CTEK could achieve. I am grateful for the suggestion.
Today I decided to plug in the GAP tool after a few hours charge today. No flickering lights on the dash, at least, but some new codes. TBH, I am putting these down to low battery voltage still. The fuel pump error piqued my interest but alas, even this excellent forum does not return any result for the code when I searched.
I inquired about resetting this pump on a 405 post, but I do not even have the option in my GAP tool.
in any event I have decided to leave the poor weather and take a month in sunnier climes, so I will not be revisiting this until April, at the earliest. I am still undecided whether to renew the insurance due to this, but I probably will. Even an immobile L322 could catch fire, right? Smile
Post #712968 27th Feb 2025 9:03pm
toby1
One year of ownership today. I couldn't find any other company cheaper than esure so it renews today.
What I find surprising is this thread has over 20,000 views. I am still working from warmer climes and not back for a few weeks yet, but I'd be lying if I said the absence has made my heart grow more fondly for it. Smile
I'll have a go at most jobs that do not require a lift, but it's not knowing what's broken that is the most annoying part, especially as it ran before my grubby mitts started on it.
This forum is a great resource though and it is a massive help. There is one other thread with a similar-sounding issue but the poster has not returned for a few months with an outcome.
I'd like to declare 'it will run again!' but I am not taking anything for granted. 2012 Vogue TDV8 in Aintree green over sand
Post #714668 23rd Mar 2025 3:32pm
GraemeS
Australia
Your non-start issue only began after you changed the fuel pressure sensor and did something to its wiring. I would revisit that wiring. D350 SE Carpathian Grey D5 19" rims
Post #715312 31st Mar 2025 10:39pm
toby1
And the upper HPFP pipe to the rail. I've been researching more elsewhere and in the W.M. and I think I am drawing up a structured plan to follow. To be continued... 2012 Vogue TDV8 in Aintree green over sand
Post #715319 1st Apr 2025 8:51am
toby1
A little bit of playing around today. I have:
1. Charged the battery fully to the green symbol on my CTEK.
2. Put in 5 litres of diesel. The gauge has definitely moved up a bit.
3. Reconnected the ECU next to the battery. Cleared the 'phone book of fault codes.
4. Ignition on for 30 seconds. The low pressure pump starts and I can feel it whirring away.
5. Ignition on for 60 seconds. The low pressure pump is running.
6. Firm press on the brake and go for a start. It catches and dies immediately. I can see a whiff of blue smoke from the engine bay.
7. Another crank. Same result as 6. DPF full yellow warning.
I leave it for a while and plug in my GAP tool. I recorded two more cranks with the following data.
I am none the wiser really, but without a second pair of eyes looking for me during the crank, I decided against more as I can't see from where the blue smoke eminates. TBC... 2012 Vogue TDV8 in Aintree green over sand
Post #715667 6th Apr 2025 4:29pm
pcourtney
did you actually double check about the ABS Control Module
these beasts need a positive message back from the ABS control module for the car to crank from the "Start Button" inside the car
they also need to see hydraulic pressure in the ABS system, you may have to bleed the brakes again to make sure this is not the problem for the no crank off the "Start Button"
to rule this out you could buy a second hand ABS Control Module off ebay for £20 quid , the part no is CH322C405AD
Post #715680 6th Apr 2025 9:14pm
toby1
It is cranking. You should be able to hear the crank in the above clips.
I made some notes from gathering information from other sources. This is mainly for my benefit so I don't go on a wild goose chase.
From a different forum:
The HP fuel pump will shut down in the event of too high a pressure by means of closing off the fuel metering valve, there is also a non-return valve in the fuel line after the fuel cooler which may be blocked / restricted.
It may also be simply fuel returning from the injector spill line which connects to the return, the non-return valve will require some pressure to actuate, removing the return line from the HPFP will cause that pressure to vent from the line there."
And from the W.M.
"The metering valve regulates the amount of fuel that is delivered to the common rails via the pumping elements. When there is no signal to the metering valve the valve is closed, therefore there is no fuel delivery.
The fuel metering valve default is closed without electrical supply. An open circuit connector will prevent the engine from running."
Post #715693 7th Apr 2025 10:10am
