Home > Technical (L405) > front knuckle cracking
Page 46 of 50 <123 ... 454647 484950>
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
Mines a 2014, and I have just checked the proposed recall N759 on the online service history and it doesn't mention it for my car.
I've read through most of the 45 pages of this thread, and from what I have gathered, it would appear to be certain VIN numbers between 2013-2018 which could relate to batches of the knuckles.
Speaking as an engineer who has spent 40 years in aerospace/military design its is not a good idea to use a split clamp arrangement where you can sustain vertical and vibration loads, I certainly wouldn't use aluminium (unless using LM series grade cast aluminium) and possibly over torque the clamp, you can see alot of the cracking on the opposite side to the bolt.
Aluminium is more susceptible to fracturing as it does not have the elasticity of steel.
Regardless I reckon either no FEA was done on this part, or an inferior grade of aluminium was used, not uncommon when getting it made in India.
LM series aluminium has good corrosion resistance and is often used where salt air corrosion can be a problem on aerospace parts.
My thinking is that when Tata took over Landrover in 2008, they directed most of their manufacturing to be done in India.
There in lies the problem!
Post #706619 11th Dec 2024 3:53pm
AndyG-RR
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Thanks for the response @goldeneye32 some very interesting thoughts, and I'm sure you are correct... 2015 SDV8 L405 Autobiography in Santorini Black
2012 TDV8 L322 Westminster in Aintree Green - running on Cooper Discoverer AT3s - written off Sad
Post #706626 11th Dec 2024 4:36pm
Extol
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
My thinking is that when Tata took over Land rover in 2008, they directed most of their manufacturing to be done in India.
These Knuckles are made in China, if you look at the recent US recall documents by the US authorities, it clearly given the Chines manufacturer detail. Just to let you all know if you decide to do this your own, like me, please check the bearings on the new replacement knuckles you buy from JLR, I had two faulty once which I had to return back to JLR. So check the bearings before you install.
Post #706641 11th Dec 2024 7:50pm
Glackowitz
United States
I recently bought (3 weeks ago) a 2016 L405 5.0 SC and found out about the recall about a week ago as it popped up in my Carfax Car Care app. Went out the other night to inspect the knuckles as my car falls into the VIN range and production dates and low and behold...Driver side cracked. Call closest dealer (4 hours away) and they couldnt tell me much other than bring it in for a diagnostic check. I agreed and asked about what we do after that and they didnt know. asked if they had a time frame for parts, didnt know, asked about continued driving again they didnt know.
so called JLR USA and they recommended calling another dealer to work with, so called next closest dealer and its 5 hours away other direction and they asked for VIN, pics, contact info and such.
Gal talked with service manager and then contacted regional person and are working on a plan to get me fixed up.
I know what dealer I will not goto again...I bought my first Range rover from them back in 2001, a 1996 4.0 SE. They didnt even have me in the database anymore.
Post #706748 13th Dec 2024 6:41am
Mikey
Another one through the workshop today
17MY, 84k miles, brought in for a routine service. She had just driven 55 miles down the motorway this morning on her way to us Shocked
Post #706812 13th Dec 2024 10:45pm
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
Related?
https://www.bbc.co.uk/news/articles/c20nr3zdppjo
Or am I being a bit 'conspiracy-theorist'?
W 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #707185 18th Dec 2024 1:30pm
Mikey
Article is confusing. From what I can make out
He worked for Tata. They arr making cars for another company called Vinfast, who were having issues with suspension components
He told senior management. They told him to F.O
He did F.O, and went to JLR
TATA wanted him sacked, and so he was sacked
Ish Laughing
Post #707203 18th Dec 2024 7:11pm
LiKuid
Greece 2017 Range Rover Autobiography TDV6 Corris Grey
I am currently changing tyres and unfortunately i seem to have a cracked ftont knuckle as well.
How dangerous is it to drive it back home? It’s a pain to take it to the dealer and leave it there over the holidays but i dont feel very nice driving it either
2017 3.0 hybrid AB
Post #707231 19th Dec 2024 2:40pm
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
There now seems to be a few 2017 models affected (at least a couple I’ve seen on Facebook asking for advice). Worrying for those of us with a 2017. 2017 (67) Vogue SE Corinthian Grey
Post #707233 19th Dec 2024 3:44pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Just found out my front nearside knuckle is cracked. Mines a 2013 SDV8 so not in the VIN range. £780 for a new one.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #707276 20th Dec 2024 11:59am
Gremlin500
Shocked I’m repeating myself for those who haven’t read this whole thread:
Don’t worry, -do something about it!!!
Idea Get an aerosol weld crack test kit, and test your knuckles with it every 6 months, or however frequently allays your fears. Better than nothing. Thumbs Up
Google “Aerosol Weld crack test kit” or search on eBay, around £15-£20, plus an hour of your time, you don’t even need to take the wheels off, just chuck a rag over them.
No excuse for not doing it before you let your loved ones in the vehicle!
These cracks take a long time to propagate, so best to catch them early, by the time you can see them, it’s almost too late! “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #707289 20th Dec 2024 3:07pm
sass
Finland 2016 Range Rover Vogue TDV6 Kaikoura Stone
Just out of curiosity:
How many of you have noticed cracked knuckles only after you have become aware of the potential defect and have thereafter started to periodically inspected them?
How long did it take foir the cracks to develop?
My vehicle falls just out of the VIN range of the officially affected ones being manufactured in April 2016. I haven't noticed any cracks so far with the naked eye or running my fingers over the metal.
The car was in for a free dealer check up this October and they only advised me to change the lower suspension arms at some stage. Obviously they would have lured me into getting the car repaired/serviced if there would have been something obvious. They even washed my car and got free LR-valve caps Cool
Post #707294 20th Dec 2024 3:49pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Mine (2016MY) was also just outside of vin range and I checked them in minute detail when the recall was first announced. Roll on to this October and noticed both cracked (o/s very badly) when changing discs and pads. Fortunately JLR replaced both and also the o/s driveshaft they destroyed whilst doing the job, their official line was outside of recall, but done under goodwill. I know people on here in a similar position haven't been so lucky and have been left to foot the bill. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #707295 20th Dec 2024 4:24pm
Gremlin500
@SASS:
I think you may have misunderstood my previous post:
If you can SEE a crack, it’s already TOO LATE, DO NOT DRIVE THE CAR!
The crack testing kit will reveal a fine crack which an unaided human eye possibly cannot see, so gives you that much more warning, again to NOT DRIVE THE CAR, as soon as the crack is revealed by the test kit.
I am NOT advocating folks drive their cars with ANY crack, no matter how hairline it is, good sense should prevail, it’s not only yourself you endanger, it’s also the public at large. Exclamation “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #707308 20th Dec 2024 6:38pm
Gsxr1250dave
LRTIME just did this on their 405 and used a crack testing kit they inspected them and thought 1 bad 1 good thectesting kit proved both were cracked. LR Germany have replaced and fixed their car and looks like it's going to be flagged up in Germany as a recall .
You can of course see the whole thing on the tube
Post #707311 20th Dec 2024 7:11pm
