Home > My Range Rover > 5 RRs and I have to give up |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 691 |
Okay so we're saying it's probably not the pipes, the pumps new, the resevoir is new, the cooler no longer leaks and the servotronic valve checks out OK. (We think)
15th Nov 2024 1:30pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 |
I agree with GraemeS, you've eliminated the Servotronic valve.
15th Nov 2024 2:06pm |
Afternoon Pawl,
15th Nov 2024 3:31pm |
Graeme, I just read your post via search regards your steering becoming heavy post input seal replacement.
16th Nov 2024 9:56am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2553 |
Yes, grit had found its way into the pump and caused the valve piston to stick open thus providing almost no pressure. Once freed, power assist was working again. |
16th Nov 2024 11:18am |
Excellent result Graeme, well done that man
16th Nov 2024 11:25am |
Okay, so I've had it up in the air today to check for binding.
16th Nov 2024 6:15pm |
I have a little bit more to add.
18th Nov 2024 10:15pm |
I think the "error" might be because the BCM outputs a PWM (Pulse Width Modulation) signal - effectively pulses of voltage to drive the Servotronic valve. The gaps between the pulses reduces as the vehicle speed reduces, so that the valve opens more. 12v is being applied - but not continuously.
18th Nov 2024 10:40pm |
I completely understand what your saying Pawl regards measuring PWM (continous on/off pulse) signals but it seems a bit redundant for LR to include this data PID in the software if its unable to read anything.
18th Nov 2024 11:13pm |
With the connector unplugged from the valve and with the engine running but the vehicle not moving, is the steering quite a lot heavier than with the connector fitted? However, I think that you've already tried this and found the steering ligher when connected. |
19th Nov 2024 9:03am |
Well today has been a very strange day indeed...
19th Nov 2024 6:43pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 760 |
amazing RR 2005 4.4 petrol
20th Nov 2024 2:11am |
Still driving okay today |
20th Nov 2024 9:59pm |
