Home > Maintenance & Mods (L405) > Oil change - which pump and which new oil and new filter?
Page 4 of 4 <1234
garyRR
I was about to say the same. Petronas 5000 FJ.
In my opinion, all things considered, the best oil for the 4.4 SDV8. 2015 Range Rover Autobiography 4.4 SDV8
Post #697054 29th Jul 2024 9:58am
Rob99
caymanblack wrote:
Let us know how that pump works Rob.
Yep, will do Thumbs Up
Just ordered this and a filter:
https://www.opieoils.co.uk/p-218910-petron...e-oil.aspx 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #697070 29th Jul 2024 2:07pm
caymanblack
Kot wrote:
LR? should be FJ there are many types of Syntium 5000 the 2 letters after 5000 are key!
I use Petronas as well, but it should be PETRONAS Syntium 5000 FJ 5W-30 Fully Synthetic Car Engine Oil
Meets or exceeds the requirements of: ACEA C1
Has the following manufacturer approvals:
Jaguar / Land Rover JLR.03.5005
Meets or exceeds the following manufacturer requirements:
Ford WSS-M2C934-B
Sorry Kot you are right I was just implying LR approved. Great value oil . overfinch modified
Post #697072 29th Jul 2024 2:51pm
Rob99
Well, got round to doing my first FF oil change yesterday and I have to say it was a doddle Thumbs Up
The pump I bought (see earlier post from me and "JayGee") to extract the oil worked great, sucking out all the oil in less than 10mins.
Couple of comments about the bits included with the pump. It has 2 metal outlet tubes which you screw into each side of the pump body and is also supplied with 3 tubes, a 10mm ID outlet tube and 2 inlet tubes (8mm/6mm), together with a couple of push fit connectors.
The oil extraction pipe on the FF needs a 8mm ID pipe so the smaller pipes and the push fit connectors were not usable. Fortunately I had some 8mm pipe at home so just cut a small length to fit between the extraction pipe and the pump using a couple of jubilee clips.
And that's it, job done in less than an hour Very Happy 2021 D350 Fifty Edition - Carpathian Grey
Post #697332 3rd Aug 2024 2:45pm
caymanblack
Good news The Rob. Thumbs Up overfinch modified
Post #697367 3rd Aug 2024 8:37pm
JayGee
👍 on the pump working OK and hose info. 2012 TDV8 Vogue (L322)
Post #697369 3rd Aug 2024 8:45pm
JayGee
Used the pump I bought a while back today
https://www.ebay.co.uk/itm/375128179778?mk...media=COPY
Works much better than the previous one but I'll be replacing the hoses for next time as they are too short. Took less than 10mins to drain the whole sump. 2012 TDV8 Vogue (L322)
Post #702111 13th Oct 2024 2:02pm
Page 4 of 4 <1234
