Home > Maintenance & Mods (L405) > Oil change - which pump and which new oil and new filter? |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1296 |
Mahle filter/Smith & Allen oil/Neilsen pump (needs small compressor, but worth having long term). |
13th Jun 2024 10:40pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 756 |
I don't see why people use the manual pumps.
13th Jun 2024 11:05pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3736 |
Try Opie oils, they do service kits, 2X 5l cans of oil plus filter element.
14th Jun 2024 9:01am |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1105 |
https://www.opieoils.co.uk/p-218910-petron...EYQAvD_BwE overfinch modified |
14th Jun 2024 12:08pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 100 |
I use a 10l bucket and the sump plug. Old style.
14th Jun 2024 6:53pm |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 75 |
+1 for Opie oils, I have used 3 times for my RR. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
15th Jun 2024 9:00am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3028 |
Just ordered one of these to try out as using my Draper Expert does involve 2 goes to get all the oil out as well as the pouring of it into my used oil jerrycan so this would make it easier. 2012 TDV8 Vogue (L322) |
15th Jun 2024 1:18pm |
That pump looks great Kev, is the tube it comes with long enough to get to the bottom of the sump ? And do you connect on the engine battery terminals? Thx.
15th Jun 2024 2:20pm |
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90 |
No need for the tube to reach the bottom of the sump as you connect the pump tube to the engine oil extraction pipe which is next to the oil filler cap. This pipe runs all the way to the bottom of the engine sump.
17th Jun 2024 4:08pm |
Yep, just connect the pipe to the suction tube and the cables to the battery posts under the bonnet and pump the oil out. Just make sure your engine oil is nice and warm and it'll suck it out in no time. Kev
22nd Jun 2024 10:15pm |
Many thanks Kev overfinch modified |
23rd Jun 2024 11:03am |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 133 |
I like crawling under the truck at least every other oil change(I'm on a 5k rotation) - gives me a chance to poke around and look at other things. I get under there and look and clean and wipe all while letting the sump drain fully. I am not in the 5 minute oil change business - so I have time.
24th Jun 2024 5:58am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1445 |
To chip in: I tried a 12V pump, a decent Sealey one, and it struggled pumping the oil up through the drain tube. I have the Draper Professional extractor and it works great, in fact it gets used on several cars a week as proof of its longevity. That gets just as much oil out as draining did. Re the oil filter, the genuine OEM used by Land Rover is Mahle OX153/7D2. It's about £12, so save yourself a shed load of cash and just order the same thing without the Land Rover box! Regarding oil, my personal preference is the Petronas 5000 FJ from OpieOils. It's about £60 for 10L, is a proper branded oil and has the Land Rover approval (not just a recommendation) to show that it complies with the standard. On my old TDV8, I still stand by the fact it significantly reduced the James Bond smoke screen over my previous experience with Valvoline and others. Have been using the Petronas on a 4.4 TDV8, my current 4.4 SDV8 and 3.0 TDV6 Jag. 2015 Range Rover Autobiography 4.4 SDV8 |
25th Jun 2024 1:07am |
Total junk. Connector blew off the outlet and covered me and the front of the car with hot engine oil. Luckily I have a lathe and was able to make a proper connector but if you don't just buy the Draper expert. Also rewired it to make the electrical lead longer and remade the suction hose connector. Took about 15 mins to drain the sump but all the time worrying the pump would burn out or sieze up. Properly implemented a pump like this could work well but this model is 2012 TDV8 Vogue (L322) |
30th Jun 2024 4:09pm |
