Home > Maintenance & Mods (L405) > Oil change - which pump and which new oil and new filter? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3028 |
The model made 3 years ago maybe not the same as the one you can buy today? 2012 TDV8 Vogue (L322) |
30th Jun 2024 7:52pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 409 |
I've found the cheap electric pumps to be utter tosh, no good for sucking 10L of oil up a 6mm (or so) diameter tube.
30th Jun 2024 8:58pm |
This looks like a slightly more robust unit with proper hose connectors.
1st Jul 2024 6:51am |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1105 |
I was looking at that one Jay also , look around as its available for £12. overfinch modified |
1st Jul 2024 12:18pm |
The stated flow rate will empty the sump in 20-30 mins according to the spec sheet and it will run for 30mins max so could be a bit marginal. This one may be better?
1st Jul 2024 12:55pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 756 |
^^^one of my family members has one of these and is very happy with it. Kev
1st Jul 2024 1:36pm |
I'll buy it for the next oil change as the one i bought is in the bin. After 3 x 95deg intensive stain wash cycles using loads of detergent I finaly got the oil stains out of my jeans. I've got an MOT on Thurs and I wonder if they will tell me I have a bad oil leak at the front of the engine..... 2012 TDV8 Vogue (L322) |
2nd Jul 2024 7:32am |
So what actually happened? Was the hose not tight enough on the pump outlet? Kev
2nd Jul 2024 8:10am |
It was tight but the design is poor so it just flew off under pressure and the heat of the oil softening the hose. 2012 TDV8 Vogue (L322) |
2nd Jul 2024 8:38am |
cheap crap ! overfinch modified |
2nd Jul 2024 10:24am |
Sounds like you had a bit of bad luck JayGee. Glad you got the oil out of your jeans. I suppose there could be a number of reasons why your hose popped off. Like you say, perhaps something has materially changed.
5th Jul 2024 10:36pm |
The flow on that is way faster than I got. The outlet had a ball with a small hole in it to retain the hose under the compression fitting which was obviously resticting flow for a start and the extraction hose in yours looks thicker - does the L405 have a wider oil extraction tube than on the L322? 2012 TDV8 Vogue (L322) |
6th Jul 2024 10:02am |
I just measured the extraction tube on the L405 and it has an OD of 8mm. What is it on the L322?
6th Jul 2024 10:39am |
That sounds the same as on the L322. 2012 TDV8 Vogue (L322) |
7th Jul 2024 12:21pm |
