Home > Maintenance & Mods (L405) > Oil change - which pump and which new oil and new filter?
Page 3 of 4 <1234>
JayGee
This just arrived
https://www.ebay.co.uk/itm/375128179778?mk...media=COPY
It's a much more substantial unit - metal body and metal fittings. Will find out if it works in 6 months when I do the next oil change 2012 TDV8 Vogue (L322)
Post #696655 22nd Jul 2024 2:58pm
caymanblack
Thanks for posting Jay, it looks a good one. overfinch modified
Post #696747 23rd Jul 2024 6:17pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I’m glad you posted that 👍
I was about to buy this 😳
https://amzn.eu/d/00uWf5di
Post #696764 23rd Jul 2024 9:35pm
caymanblack
A couple of beers in that Richie! Thumbs Up overfinch modified
Post #696787 24th Jul 2024 10:15am
Richie N
Post #696835 24th Jul 2024 8:49pm
Baltic Blue
This looks interesting, especially if like me you already have Makita 18v drill and spare battery.
Unfortunately I haven’t seen a UK supplier with a price quoted in £, avoiding import duty and delivery costs.
Post #696972 27th Jul 2024 11:19am
JayGee
Is it designed for hot engine oil or just diesel? 2012 TDV8 Vogue (L322)
Post #696974 27th Jul 2024 11:56am
Baltic Blue
It says it can be used for oil changes ?
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #696975 27th Jul 2024 12:02pm
I get cordless for things like tyre inflators - I have one & love it. However, given the distance between the drain tube & the battery / power points under the bonnet, it's not exactly a hardship to connect up a 12v one.
Post #696978 27th Jul 2024 1:03pm
Baltic Blue
Apologies for taking this off topic, but I agree Alistair, my kids bought me a Makita tyre inflator that uses the same 18v battery and it is brilliant., takes a virtually flat tyre up to 36psi in minutes, no problem
Cheers
Post #696979 27th Jul 2024 1:22pm
Rob99
JayGee wrote:
This just arrived
Now I'm tending to do many more shorter trips in the FF I'm starting to come up against the oil dillution issue much sooner than before. It used to be around 6months or 6000 miles and I used to gat a special price from the dealer which wasn't much more than it would have cost me just for the oil and filter and I just didn't fancy the mess either.
Now it's only been about 3000 miles since the last service and oil change and I'm getting the service warning coming up. The dealer's special rate isn't available any more and I've no desire to pay them over £300 for an oil change every few months when it seems like such a straightforward job and no lying on my back on the drive Thumbs Up
Hence I've just bought one of these pumps myself. Looks ok but will find out in a couple of weeks when I do my first FF oil change. Shocked Shocked
Oil and filter purchase next. Had a look on the Opie site for the Petronas Syntium LR spec oil and just wondered what peoples views are on the price range of oils which, essentailly are all of the approved LR spec. Prices seem to go from £60 for 10L of Petronas to almost £150 for the Motul. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #697038 28th Jul 2024 6:16pm
JayGee
If you are changing oil due to fuel contamination then just buy the cheapest C1 5w-30. 2012 TDV8 Vogue (L322)
Post #697043 28th Jul 2024 7:15pm
Richie N
I agree. I usually buy premium oil, but it looks like I might be doing 2k oil changes so I’ll be buying cheaper brands.
Post #697044 28th Jul 2024 8:38pm
caymanblack
I use the Petronas Syntium LR its a good oil imo.
Let us know how that pump works Rob. overfinch modified
Post #697051 29th Jul 2024 9:02am
Kot
LR? should be FJ there are many types of Syntium 5000 the 2 letters after 5000 are key!
I use Petronas as well, but it should be PETRONAS Syntium 5000 FJ 5W-30 Fully Synthetic Car Engine Oil
Meets or exceeds the requirements of: ACEA C1
Has the following manufacturer approvals:
Jaguar / Land Rover JLR.03.5005
Meets or exceeds the following manufacturer requirements:
Ford WSS-M2C934-B 2018 SE SDV8 4.4 Byron Blue
Post #697053 29th Jul 2024 9:56am
Page 3 of 4 <1234>
