Home > Maintenance & Mods (L405) > Auto Start Stop Disabled with GAP tool |
unsolicited Member Since: 30 May 2016 Location: London Posts: 124 |
Seems to work. The whole CCF write is a scary thing, with ignition off/on/off Christmas tree lights and some of the car settings need re-inputting afterward (AEB off etc.)
13th Apr 2024 7:01pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
or, you can simply disconnect the earth to the rear cubby battery [if you have one] or disconnect the signal wire to the capacitor, again in the rear cubby.. ... - .- -.
13th Apr 2024 8:32pm |
Indeed. I guess the advantage of the CCF change is you can re-enable it on the switch if you want though. |
20th Apr 2024 11:25am |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 583 |
Just done this. Scarey for numpties like me with all the warnings! But appears to have worked - certainly worked for a couple of test starts after finishing, will see if it remembers when I use the car properly tomorrow! Thanks for posting - I hate stop/start and nearly all other driver "aids" so default off is nearly always my pref - can switch it back on in a queue situation or when stationary for longer than normal - which is what I did manually before. Mike - MPx
2nd May 2024 2:03pm |
ajnath04 Member Since: 22 Apr 2024 Location: Atlanta, GA Posts: 2 |
I tried to look for the CCF files on the GAP tool, could not find them under the Main CCF ! I have 2016 RR 3.0 Petrol engine.
20th May 2024 5:21pm |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 |
Anyone tried this on a 2013 TdV6? Want to do this CCF change.
5th Jun 2024 7:43am |
strange ,i never got any error messages at all ..
5th Jun 2024 8:52am |
Yes, just disconnected the earth lead. 2013 L405 3.0 TdV6 Autobiography Barolo Black
5th Jun 2024 6:35pm |
it could be the aux battery is supplementing the main battery which could be low on power
5th Jun 2024 6:47pm |
Happy to report that the IIDTool change worked on mine so it starts up with it switched off every time and I can switch it on whenever I want on the switch. Perfect. I just followed the steps in the vid posted - must have watched it half a dozen times in the car to make sure I was doing the right thing LOL! Mike - MPx
5th Jun 2024 7:00pm |
Thanks for your thoughts.
5th Jun 2024 7:01pm |
Really tempted to do this too Mike! Anyone done it on a 2013 MY? 2013 L405 3.0 TdV6 Autobiography Barolo Black
5th Jun 2024 7:03pm |
Today tried to do this mod. Unfortunately I can't get a complete list of Car Config in the app. It only has a (very) limited "confirmed list" available. Anybody any idea how to solve this?
10th Jun 2024 2:05pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8189 |
You need to email GAP and ask them for the full, unconfirmed list, then you update your IID and it will all be there....
10th Jun 2024 5:11pm |
