Home > Maintenance & Mods (L405) > Auto Start Stop Disabled with GAP tool |
unsolicited Member Since: 30 May 2016 Location: London Posts: 123 |
Seems to work. The whole CCF write is a scary thing, with ignition off/on/off Christmas tree lights and some of the car settings need re-inputting afterward (AEB off etc.)
13th Apr 2024 8:01pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34956 |
or, you can simply disconnect the earth to the rear cubby battery [if you have one] or disconnect the signal wire to the capacitor, again in the rear cubby.. ... - .- -.
13th Apr 2024 9:32pm |
Indeed. I guess the advantage of the CCF change is you can re-enable it on the switch if you want though. |
20th Apr 2024 12:25pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 538 |
Just done this. Scarey for numpties like me with all the warnings! But appears to have worked - certainly worked for a couple of test starts after finishing, will see if it remembers when I use the car properly tomorrow! Thanks for posting - I hate stop/start and nearly all other driver "aids" so default off is nearly always my pref - can switch it back on in a queue situation or when stationary for longer than normal - which is what I did manually before. Mike - MPx
2nd May 2024 3:03pm |
ajnath04 Member Since: 22 Apr 2024 Location: Atlanta, GA Posts: 2 |
I tried to look for the CCF files on the GAP tool, could not find them under the Main CCF ! I have 2016 RR 3.0 Petrol engine.
20th May 2024 6:21pm |
