Home > Maintenance & Mods (L405) > Auto Start Stop Disabled with GAP tool
Page 1 of 3 123>
Doublejjd
United States 2017 Range Rover 5.0 SC V8 Waitomo Grey
Just did this on my 2017 L405 LWB SC with gap tool...worked perfectly.
Car defaults to auto start/stop off.
just fyi!
Post #690103 6th Apr 2024 4:25pm
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
Seems to work. The whole CCF write is a scary thing, with ignition off/on/off Christmas tree lights and some of the car settings need re-inputting afterward (AEB off etc.)
However - the car now remembers the start/stop setting across starts. Hallelujah.
Post #690541 13th Apr 2024 7:01pm
or, you can simply disconnect the earth to the rear cubby battery [if you have one] or disconnect the signal wire to the capacitor, again in the rear cubby.. ... - .- -.
Post #690552 13th Apr 2024 8:32pm
unsolicited
Indeed. I guess the advantage of the CCF change is you can re-enable it on the switch if you want though.
Post #690974 20th Apr 2024 11:25am
Just done this. Scarey for numpties like me with all the warnings! But appears to have worked - certainly worked for a couple of test starts after finishing, will see if it remembers when I use the car properly tomorrow! Thanks for posting - I hate stop/start and nearly all other driver "aids" so default off is nearly always my pref - can switch it back on in a queue situation or when stationary for longer than normal - which is what I did manually before. Mike - MPx
Post #691760 2nd May 2024 2:03pm
ajnath04
United States 2016 Range Rover HSE 3.0 SC V6 Fuji White
I tried to look for the CCF files on the GAP tool, could not find them under the Main CCF ! I have 2016 RR 3.0 Petrol engine.
Does any have a video for a Range Rover ?
Post #693038 20th May 2024 5:21pm
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Anyone tried this on a 2013 TdV6? Want to do this CCF change.
@ Stan; disconnecting the rear cubby battery seemd to work fine until after 50 km drive I got the "restricted performance" Censored message. Reconnected the battery and never a restricted performance message again. But still the annoying start/stop Evil or Very Mad thingie so want to cure that one Laughing 2013 L405 3.0 TdV6 Autobiography Barolo Black
2004 L322 3.0 Td6 Vogue Cairns Blue (gone)
2000 P38 2.5 DSE (gone)
Post #693904 5th Jun 2024 7:43am
strange ,i never got any error messages at all ..
did you just disconnect the earth/negative ? ... - .- -.
Post #693907 5th Jun 2024 8:52am
Rangie4fun
Yes, just disconnected the earth lead. 2013 L405 3.0 TdV6 Autobiography Barolo Black
Post #693931 5th Jun 2024 6:35pm
it could be the aux battery is supplementing the main battery which could be low on power
so check the main battery to make sure its at full power. ... - .- -.
Post #693933 5th Jun 2024 6:47pm
Happy to report that the IIDTool change worked on mine so it starts up with it switched off every time and I can switch it on whenever I want on the switch. Perfect. I just followed the steps in the vid posted - must have watched it half a dozen times in the car to make sure I was doing the right thing LOL! Mike - MPx
Post #693938 5th Jun 2024 7:00pm
Rangie4fun
Thanks for your thoughts.
Had so far no issues that pointed in that direction though... 2013 L405 3.0 TdV6 Autobiography Barolo Black
Post #693939 5th Jun 2024 7:01pm
Rangie4fun
Really tempted to do this too Mike! Anyone done it on a 2013 MY? 2013 L405 3.0 TdV6 Autobiography Barolo Black
Post #693940 5th Jun 2024 7:03pm
Rangie4fun
Today tried to do this mod. Unfortunately I can't get a complete list of Car Config in the app. It only has a (very) limited "confirmed list" available. Anybody any idea how to solve this?
Question Bow down
BTW: I had the most recent firmware on the GAP which didn't show more than the confirmed list. After that I reinstalled the firmware to no avail Sad 2013 L405 3.0 TdV6 Autobiography Barolo Black
Post #694210 10th Jun 2024 2:05pm
You need to email GAP and ask them for the full, unconfirmed list, then you update your IID and it will all be there....
My tip, take screengrabs of any setting you change... Thumbs Up Pete
Post #694223 10th Jun 2024 5:11pm
Page 1 of 3 123>
