![]() | Home > Maintenance & Mods (L405) > Auto Start Stop Disabled with GAP tool |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2652 ![]() ![]() |
How is the cover removed please? I need to disconnect the capacitor in my MY21 until I own a Gap tool that will do the CCF change. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
pull from the top left and work your way along the top... ... - .- -.
Thanks Stan. I had started in that area but chickened-out. I'll have another attempt tomorrow. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
My 2014 L405 SDV8 came from the factory with no stop start, (thankfully) not even the switch. I have a large auxiliary battery.
As Stan says, but you have to pull so hard that you think you will break it, I use the vent in the recessed bit as you can get your fingers thought the slots to get a good grip, then a sharp, violent yank straight out towards the other side of the boot....... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Thanks Pete, noted. |
Mine probably doesn't have a capacitor as it has a 48V battery, but hopefully I'll find something to disconnect. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6768 ![]() ![]() ![]() |
I disconnected the auxiliary battery and the heated steering wheel and seats stopped working |
I've removed cargo area fuse 34 MHEV 5A. There's now a red triangle in the top right of the instrument display directly below when the stop/start icon shows but it seems that stop-start is disabled. If that's all the repercussions then it can stay that way until I decide to get a G4 IIDtool.
