![]() | Home > Maintenance & Mods (L405) > Auto Start Stop Disabled with GAP tool |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 128 ![]() ![]() ![]() |
Seems to work. The whole CCF write is a scary thing, with ignition off/on/off Christmas tree lights and some of the car settings need re-inputting afterward (AEB off etc.)
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35479 ![]() ![]() |
or, you can simply disconnect the earth to the rear cubby battery [if you have one] or disconnect the signal wire to the capacitor, again in the rear cubby.. ... - .- -.
Indeed. I guess the advantage of the CCF change is you can re-enable it on the switch if you want though. |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 601 ![]() ![]() ![]() |
Just done this. Scarey for numpties like me with all the warnings! But appears to have worked - certainly worked for a couple of test starts after finishing, will see if it remembers when I use the car properly tomorrow! Thanks for posting - I hate stop/start and nearly all other driver "aids" so default off is nearly always my pref - can switch it back on in a queue situation or when stationary for longer than normal - which is what I did manually before. Mike - MPx
ajnath04 Member Since: 22 Apr 2024 Location: Atlanta, GA Posts: 2 ![]() ![]() ![]() |
I tried to look for the CCF files on the GAP tool, could not find them under the Main CCF ! I have 2016 RR 3.0 Petrol engine.
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 165 ![]() ![]() ![]() |
Anyone tried this on a 2013 TdV6? Want to do this CCF change.
strange ,i never got any error messages at all ..
Yes, just disconnected the earth lead. 2013 L405 3.0 TdV6 Autobiography Barolo Black
it could be the aux battery is supplementing the main battery which could be low on power
Happy to report that the IIDTool change worked on mine so it starts up with it switched off every time and I can switch it on whenever I want on the switch. Perfect. I just followed the steps in the vid posted - must have watched it half a dozen times in the car to make sure I was doing the right thing LOL! Mike - MPx
Thanks for your thoughts.
Really tempted to do this too Mike! Anyone done it on a 2013 MY? 2013 L405 3.0 TdV6 Autobiography Barolo Black
Today tried to do this mod. Unfortunately I can't get a complete list of Car Config in the app. It only has a (very) limited "confirmed list" available. Anybody any idea how to solve this?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8368 ![]() ![]() ![]() |
You need to email GAP and ask them for the full, unconfirmed list, then you update your IID and it will all be there....
