![]() | Home > Technical (L322) > much ado about rear suspension overhaul |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
Right so all installed with hubs
Depends how thick the metal is and what the tolerance for the brake retaining pins is as any form of 'panel work' may push things out of alignment so just cutting it would be best in this respect. A turned edge however is usualy a structural feature on thin sheet work so if it can be carefuly eased out to create clearance it may be better but I'd do it gradualy with a hammer on a solid surface. 2012 TDV8 Vogue (L322) |
so am hoping not to bend that far, just purely the lip flattening, so i guess ill need to support that joint somehow to make sure it doesnt mess with the rest of the shield.
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 113 ![]() ![]() ![]() |
You definitely don’t want to distort the back plate, it will impact the operation of the brake shoes. The shoes need to on a flat surface.
probably true, ill just cut it down and clean it up.
Managed to snake it out. Ground it back to metal and treated it Its actually a sport |
If they are the same design as the fronts they are bonded to the bar and you replace the whole bar 2012 TDV8 Vogue (L322) |
then why do they sell separate bushes for it that i seem to have bought? |
Looks like the later models have bonded bushes
Ah balls
things are starting to take shape on the left side. everything is more or less in.
to follow the above
another follow up to a follow up
right on the home stretch
