Home > Technical (L322) > much ado about rear suspension overhaul |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 399 |
Right so all installed with hubs
18th May 2024 9:34pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3201 |
Depends how thick the metal is and what the tolerance for the brake retaining pins is as any form of 'panel work' may push things out of alignment so just cutting it would be best in this respect. A turned edge however is usualy a structural feature on thin sheet work so if it can be carefuly eased out to create clearance it may be better but I'd do it gradualy with a hammer on a solid surface. 2012 TDV8 Vogue (L322) |
19th May 2024 7:41am |
so am hoping not to bend that far, just purely the lip flattening, so i guess ill need to support that joint somehow to make sure it doesnt mess with the rest of the shield.
19th May 2024 9:47am |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 111 |
You definitely don’t want to distort the back plate, it will impact the operation of the brake shoes. The shoes need to on a flat surface.
19th May 2024 10:29am |
probably true, ill just cut it down and clean it up.
19th May 2024 11:01am |
Managed to snake it out. Ground it back to metal and treated it Its actually a sport
19th May 2024 12:50pm |
If they are the same design as the fronts they are bonded to the bar and you replace the whole bar 2012 TDV8 Vogue (L322) |
19th May 2024 2:53pm |
then why do they sell separate bushes for it that i seem to have bought? Its actually a sport
19th May 2024 2:54pm |
Looks like the later models have bonded bushes
19th May 2024 6:18pm |
Ah balls
19th May 2024 7:17pm |
things are starting to take shape on the left side. everything is more or less in.
21st May 2024 7:02am |
to follow the above
21st May 2024 2:50pm |
another follow up to a follow up
21st May 2024 4:00pm |
right on the home stretch
27th May 2024 9:57am |
