Home > My Range Rover > Back with another Supercharged! A 5.0 this time!
Page 9 of 15 <123 ... 8910 ... 131415>
dhallworth
That’s the plan.
It’ll be wheels off, all arch liners out, steam cleaned and then protected. Reading a lot online about Lanoguard just now. Seems to get some decent reviews but needs topping up annually. It’s easy to apply though so not the end of the world. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #674997 6th Oct 2023 12:56pm
I've read loads about Lanoguard and I have to say what put me off was the "do it every year" comment..
I've just done rust/corrosion correction and protection with mine whilst doing the ARC pipes, used various Dinitrol products for use on rust, to prevent rust, and to treat the box sections. I would hope they will last a lot longer than a year, especially when removing arch liners that, to be frank, were a total ball ache on the 405... I did think of getting some Lanoguard and doing everything I could see without removing anything just to give it all a coating but that might be a bit OTT...
I suppose whatever we do will be an improvement... Thumbs Up Pete
Post #675001 6th Oct 2023 2:10pm
dhallworth
Well, we’re just over 100 miles in so far and nothing much to report!
Car is running great, no coolant leaks or oil leaks that I can see or smell so fingers crossed it’s good to go!
It does need a couple of bushes at the front. The steering feels a little vague and if you brake sharply you get a clunk from something. Lemforder made the OE bushes so I think I’m going to replace both bushes on the lower arm, I’ll replace the upper arm as it’s got an integral ball joint, and I’ll replace both ball joints in the hubs. Once those are done it should be perfect. Smile
Post #675119 8th Oct 2023 10:55pm
dhallworth
Now a couple of hundred miles in and she’s running great. Fuel light came on last night so I ran it a bit lower today, stuck 10 gallons of fuel in it and poured in a can of BG44K Platinum injector cleaner. It said on the tin it treated 10-20 gallons of fuel so I thought 45 litres of fuel would give it a decent concentration.
One thing I had noticed with it was that when braking anything other then gently there was a clunk from the front and if you were pressing on it felt a bit wandery.
Today I fitted 2 new Land Rover ball joints into both front hubs, 2 of the arms have integral ball joints so these were replaced with new arms, and I replaced the bushes in the 2 cranked arms that bolt to the ball joints mounted to the hubs.
Got everything refitted, then put the car back on it’s wheels, put the suspension right up, then right down and back to normal ride height and then torqued all the bolts.
When I removed the old parts, none of them were noticeably worn but when wiggling the bushes the rubber had gone soft and perished. They all looked to be the originals to the car so I can’t complain.
Taking it for a run tonight shows a big improvement in the way the car handles and there’s no annoying clunk Smile
Hoping to go away in it for a few days next week so will give it another oil and filter change again next weekend to ensure it’s running on nice clean oil and that it’s had a flush after all the work that was done on it.
Been a busy day today as before doing these bushes I swapped the steering box out on our P38 as well. My shoulders need a few days off now!
Post #675564 14th Oct 2023 10:07pm
Well done David… How’s that back shelf looking? Or did I miss an update?
Post #675565 14th Oct 2023 10:55pm
All sorted for now then.... enjoy... Thumbs Up Pete
Post #675566 14th Oct 2023 10:58pm
dhallworth
Thanks guys Smile
Parcel shelf is fitted, Craig. It’s still cream at the moment though. It’s on the list of things to do at some point. Thumbs Up 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #675575 15th Oct 2023 10:46am
dhallworth
Well, after the recent weather we’ve had in Scotland, surprisingly, today was lovely so I decided to give the Range Rover a wash.
Took just over 4hrs and I’ve not looked at the interior or treated the glass yet.
The exhaust tailpipes were disgusting so I spent ages tidying these up. The results are great!
The wheels were cleaned with fallout remover. It took 3 goes before the fallout remover stopped lifting out contaminants. Once that was done I gave the tyres a going over with some tyre shampoo and a brush. Surprising the amount of stuff it removes even after the tyres were pressure washed.
I then gave the steps a good going over with fallout remover, tar remover and gave them a wash with some shampoo.
The bodywork was then gone over with a citrus degreaser and then rinsed, snow foamed and rinsed, then washed with a lambs wool washmitt and rinsed again. Then as a cheat as I was running out of time I gave it a coat of Gyeon Wet Coat.
Must admit I’m over the moon with the results. Hopefully tomorrow I’ll get time to treat the glass then give the interior a going over. The interior doesn’t need much but I’d like to get some decent leather treatment into the seats.
Post #676082 21st Oct 2023 9:26pm
Looks great, by the time you have treated all the leather in an autobiography you will have used two bottles, it won't be a 5min job.......!!! Shocked Pete
Post #676084 21st Oct 2023 9:35pm
dhallworth
I’ll have a cricked neck by the time I’ve finished looking up at the headliner! Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #676085 21st Oct 2023 10:04pm
RangeRov
Sweden
What did you use for the exhaust tailpipes? They looked great!
Post #676143 22nd Oct 2023 3:53pm
dhallworth
I used Solvol Metal Polish with a microfibre cloth and a lot of elbow grease.
For the very tips there was a lot of carbon on them so I used a tiny Snap On polishing tool with a very fine abrasive pad to clear the carbon deposits. Once I’d shifted them I switched back to Autosol and a cloth to finish them off.
I’ve used the same polish on all 3 of my SC’s now and it’s always worked wonders. Thumbs Up
Post #676148 22nd Oct 2023 4:50pm
dhallworth
When I got the Range Rover it had a different spare wheel under the boot floor. I checked the build sheet for the car and realised that the car was on the correct wheels and it was indeed just the spare that was wrong.
I sold the “wrong” wheel on Gumtree and then kept an eye on Facebook Marketplace, Gumtree and eBay and eventually came across the correct wheel for it. I bought it from a bloke in Birmingham and then used Shiply to have it delivered to me. The finish on it is the correct colour but it’s not in great shape. My plan is to get the wheels on the car refurbished once winter has passed so I’ll get the spare done as well.
The tyre on the new wheels was knackered when it arrived. Last year I got a puncture in my black L322 which was questionable as to whether or not it should be repaired. I replaced the tyre but kept the old one. I decided as a spare for this car it would be fine so I’ve repaired it today, mounted it to the spare, balanced it and after giving it a wash and fitting the spare wheel lifting strap, put it under the boot floor.
When I climbed onto the tailgate to attach the spare wheel lifting strap one of the tailgate straps broke. The wire came out of the crimp. I called Duckworths and ordered a pair of them. Was amazed to find they were £98 a pair even after a 20% discount! Shocked
Once that was done I took all the mats out of the car, gave the car a good hoover, wiped all the trims down, pressure washed the mats and rubbed some treatment into them. I then fitted the little guys car seat base too. I was going to treat the leather too but I don’t like the stuff that I’ve got on perforated leather. Has anyone got any recommendations on a decent leather conditioner?
Anyway, it’s done for now and I’m quite happy with the results.
It’s done 300 miles since the chains were done now so whilst I was out tinkering tonight I gave it an oil and filter change as well. I chucked in a can of Millers engine flush, let it idle for 15 minutes as per the instructions and then drained the oil via the sump plug rather then the suction method.
It’s now filled up with 8 litres of Fuchs Titan 0w20 and has a genuine Land Rover filter on it.
Got a strange issue with the car that I’m about to start another thread on but she’s running great. This engine is soooo quiet with the new chains on it.
Post #676272 23rd Oct 2023 9:42pm
JamboM3
Seriously lovely machine and even the arches look clean. Great find and glad to hear it is behaving!
Post #676356 24th Oct 2023 7:37pm
dhallworth
The arches on this one are absolutely spotless. Smile
I’m a big believer in prevention being better then cure so my plan is to remove the cill covers and arch liner to give everything a bloody good clean and then to get loads and loads of protection on it.
Got a few little modifications I’d like to do to it too, well, retrofits rather than modifications.
Auto High Beam Assist. I believe this is just changing the mirror and updating the CCF.
Blind Spot Monitoring. This is just a sensor behind each corner of the rear bumper but it means changing the mirror glass. They don’t come up second hand and are around 800 quid each new Sad
Post #676361 24th Oct 2023 7:45pm
