Home > Technical (L405) > front knuckle cracking
Page 24 of 50 <123 ... 232425 ... 484950>
Andy_Butler
Here is another one to add to the list. Mine is a 2013 4.4AB driver side knuckle cracked.
Post #670292 2nd Aug 2023 9:45am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Good find, lucky escape! BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #670295 2nd Aug 2023 9:58am
Kot
Wow lucky find.
Report it here---- https://www.gov.uk/vehicle-recalls-and-fau...ety-defect
Document repair and hold on to old unit and also consider the other side is likely to fail as well
Maybe worth paying for a 3rd party inspector? example?
https://www.themotorombudsman.org/consumer...le-reports 2018 SE SDV8 4.4 Byron Blue
Post #670297 2nd Aug 2023 10:09am
2013 Shocked That seems to have expanded the impacted VIN range.....
Post #670299 2nd Aug 2023 10:25am
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
Is it worth those on here who have been affected by these failures, clubbing together and having a selection of the failed units examined by a qualified metallurgist for an educated assessment of the failures? First time FFRR owner
Post #670313 2nd Aug 2023 4:05pm
Andy_Butler
I’m going to show mine to a guy I know who is a metallurgist for BAE systems (and landrover enthusiast)
Post #670342 2nd Aug 2023 9:16pm
Andy_Butler
All fixed now. Phew!
Post #670380 3rd Aug 2023 3:02pm
Andy_Butler
I was in a hurry (driving to Cornwall on Sunday) so I found a good used part and installed it today.
The only hitch was the replacement was missing the steel taper the track rod end would locate in so I had to recover that from the failed knuckle and bond it into the new one. I have no idea how they breakers managed to get it out, must have trashed the ball joint with a hammer instead of using a splitter.
Post #670381 3rd Aug 2023 3:06pm
Fifth Horseman
Another one caught just in time (2018 SDV8 - left side)
Post #670888 10th Aug 2023 1:15pm
Jay Porsche
United Kingdom 2017 Range Rover Vogue SE TDV6 Fuji White
Thanks for highlighting. Checked mine and all good. I will check regularly from now on!
Post #670893 10th Aug 2023 3:13pm
Kot
Just seen this Topix field action released by email, cant access it as I dont have Topix access.
I am sure 1 of you can enlighten us all.
Field Actions
N759 - Front Knuckle Cracking
https://topix.jlrext.com/topix/content/doc...oupId=1585 2018 SE SDV8 4.4 Byron Blue
Post #671259 16th Aug 2023 8:24am
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
This is what mine shows.
Post #671263 16th Aug 2023 8:53am
mine,
Post #671266 16th Aug 2023 9:07am
it appears that Landrover are doing a safety recall on the L405 front knuckles..
the recall ref is N759..
you can check yours by putting your vin number into Topix or your online service history..
enter your vin number in the online service history here,
https://osh.landrover.com/ ... - .- -.
Post #671267 16th Aug 2023 9:16am
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Just checked Topix for mine and it’s showing that “ There are currently no outstanding Field Service Actions for this vehicle”.
Would be good to try and get a handle on the range of this recall - interesting that Stan’s MY16 is affected and mine apparently not. 2016 SDV8 AB
Post #671270 16th Aug 2023 9:45am
