![]() | Home > Technical (L322) > Universal Wheel bearing removal kits - word of warning |
Can the thread apply enough force to push out a bearing this size? 2012 TDV8 Vogue (L322) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
I concur, last one I changed took just under 20 tons to get it out, I doubt the threads on that kit will apply that much force.. Hope it does for you though... |
Buckie1967 Member Since: 26 Jul 2022 Location: County Durham Posts: 41 ![]() ![]() ![]() |
I'll find out when I get the new sleeve made up but I think it will. The bearing was moving out until it reached the lip of the sleeve and then it wouldn't go any further due the bearing not being small enough to fit into the sleeve.
Oh, and buy another tub of Celebrations, that ones empty.... |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1236 ![]() ![]() ![]() |
Good tip, also there are kits with more pieces that could fit, but they will also be more expensive |
I can't put my bearing in the freezer for fear that my Mrs will come across it and end up cooking it! |
Glad it worked OK... |
That's probably as good if not better quality than the original kit parts |
Yes it is quality....better than what is supplied in the kit.
I have posted an answer to your bearing fitting question, sorry if it's long winded |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
ah thanks for the warning |
The overall height including lid is 75mm and the outside diameter is 115mm the important internal diameter is 100mm so that is can accommodate the bearing that is being pushed out. |
