Home > Technical (L322) > Universal Wheel bearing removal kits - word of warning
Buckie1967
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Buckingham Blue
I am changing all four wheel bearings and decided to get one of thee kits from Amazon to help remove/fit the bearings.
Good kit and a clever little concept if you don't have access to a machine shop press. The kit is designed to push the bearings out into a "sleeve" and the kit contains different sized sleeves to suit different sized bearings to receive the bearings when they are pushed out. It also has different sized discs to do the "pushing". The "pushing" discs are fine and there is a vast arrange of sizes however the issue is the "sleeves" of which there is just a choice of four different sizes and none of the "sleeves" are suitable for the L322 bearing as the bearing is around 96mm in diameter and the largest "sleeve" in the kit frustratingly has an internal diameter of around 93mm!!! Only slightly too small but small enough to mean it won't work as the sleeve is incapable of receiving the bearing as it is being squeezed out......it ain't going to work on the L322 bearings!
I am getting a mate to make me a sleeve in his work shop with an internal diameter of 100mm to allow me to use the kit and I am confident it will work but just a word of warning to any member considering purchasing one of these kits to sort out their wheel bearings.
Post #663932 12th May 2023 11:26am
JayGee
Can the thread apply enough force to push out a bearing this size? 2012 TDV8 Vogue (L322)
Post #663933 12th May 2023 11:33am
I concur, last one I changed took just under 20 tons to get it out, I doubt the threads on that kit will apply that much force.. Hope it does for you though... Thumbs Up Pete
Post #663935 12th May 2023 11:36am
Buckie1967
I'll find out when I get the new sleeve made up but I think it will. The bearing was moving out until it reached the lip of the sleeve and then it wouldn't go any further due the bearing not being small enough to fit into the sleeve.
I had the hub in a vice and was using a 2ft breakers bar to turn the nut.
Post #663936 12th May 2023 11:36am
Oh, and buy another tub of Celebrations, that ones empty.... Laughing Pete
Post #663937 12th May 2023 11:38am
Buckie1967
Post #663938 12th May 2023 11:51am
Merchy
Good tip, also there are kits with more pieces that could fit, but they will also be more expensive Big Cry
A tip for those without a bearing press
When fitting the new bearing into the knuckle, the day before put the new bearing into the freezer and if possible heat up the knuckle with ie boiling water, you will be amazed at how easy it is to fit the bearing, standard practice at at sea ( On a huge variety of machinery) very often the bearings fit in by hand, let the knuckle cool / bearing warm up and bingo, you have a nice interference fit - Just check all sizes of components first Thumbs Up
Post #663960 12th May 2023 4:36pm
Buckie1967
I can't put my bearing in the freezer for fear that my Mrs will come across it and end up cooking it!
Post #663965 12th May 2023 5:27pm
Buckie1967
The machine shop lads knocked me up a cracking sleeve with some 100mm internal diameter steel pipe and a nice lid.
Worked a treat.....both bearings out.
Now let's see how it copes with putting some new ones back in.
Post #664088 14th May 2023 2:45pm
Glad it worked OK... Thumbs Up Pete
Post #664089 14th May 2023 3:18pm
Merchy
That's probably as good if not better quality than the original kit parts Thumbs Up We make push / pull parts at sea from steel pipe all the time.
Mark the part and keep it with the kit, you can then say the kit is for FFRR's if you sell it Whistle Rolling with laughter
Post #664098 14th May 2023 4:36pm
Buckie1967
Yes it is quality....better than what is supplied in the kit.
Before sinking the new bearings into the knuckle I am trying to find out if there is a certain way they need to be fitted......maybe to do with the ABS sensor? I have started a new thread to try and find out.
Post #664101 14th May 2023 4:50pm
Merchy
I have posted an answer to your bearing fitting question, sorry if it's long winded Embarassed
Post #664105 14th May 2023 5:21pm
mgrover
ah thanks for the warning Smile ill get a 100mm made before I embark on this
if you've got exact measurements of the sleeve and plate i wouldnt say no Very Happy
cheers Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #676457 25th Oct 2023 9:10pm
Buckie1967
The overall height including lid is 75mm and the outside diameter is 115mm the important internal diameter is 100mm so that is can accommodate the bearing that is being pushed out.
Post #676462 25th Oct 2023 9:39pm
