Home > Technical (L322) > Universal Wheel bearing removal kits - word of warning
fanguy
I am intrested in buying this kit as i want to do mine. cant find on Amazon though
Post #676982 1st Nov 2023 10:53am
mgrover
any generic wheel bearing kit will do. its like 50quid on ebay.
its the bigger sizes that are the issue.
a rough measure of the new bearing
https://photos.app.goo.gl/gho5ustGBbYfCjD48 Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #676983 1st Nov 2023 10:57am
fanguy
okay currently looking at options on ebay
Post #677461 7th Nov 2023 9:50am
mgrover
I bought this
https://www.ebay.co.uk/itm/204393958890
and
https://www.ebay.co.uk/itm/183101678490
The bottom one is if you indeed to reuse the same hubs. I won't be as I have nice shiny new ones but I do a lot of motorcycle head bearings so kinda had enough of dremeling the race.
I am currenty just toying with the idea of dropping the entire rear subframe Its actually a sport Sad
Post #677462 7th Nov 2023 9:53am
fanguy
Thanks
Post #677463 7th Nov 2023 9:55am
pcourtney
Buckie1967 wrote:
The overall height including lid is 75mm and the outside diameter is 115mm the important internal diameter is 100mm so that is can accommodate the bearing that is being pushed out.
Thank you Buckie for this info Smile
Post #699389 3rd Sep 2024 4:19pm
mgrover
I ended up using a bearing puller as a make shift press
Also used the old bearings to tap in the new ones
Then second time I used old bearing to press Its actually a sport Sad
Post #699394 3rd Sep 2024 5:30pm
