Home > Technical (L322) > Universal Wheel bearing removal kits - word of warning |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3052 |
Can the thread apply enough force to push out a bearing this size? 2012 TDV8 Vogue (L322) |
12th May 2023 11:33am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8066 |
I concur, last one I changed took just under 20 tons to get it out, I doubt the threads on that kit will apply that much force.. Hope it does for you though... Pete
12th May 2023 11:36am |
Buckie1967 Member Since: 26 Jul 2022 Location: County Durham Posts: 40 |
I'll find out when I get the new sleeve made up but I think it will. The bearing was moving out until it reached the lip of the sleeve and then it wouldn't go any further due the bearing not being small enough to fit into the sleeve.
Oh, and buy another tub of Celebrations, that ones empty.... Pete
12th May 2023 11:38am |
12th May 2023 11:51am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1158 |
Good tip, also there are kits with more pieces that could fit, but they will also be more expensive
12th May 2023 4:36pm |
I can't put my bearing in the freezer for fear that my Mrs will come across it and end up cooking it! |
12th May 2023 5:27pm |
14th May 2023 2:45pm |
Glad it worked OK... Pete
14th May 2023 3:18pm |
That's probably as good if not better quality than the original kit parts We make push / pull parts at sea from steel pipe all the time.
14th May 2023 4:36pm |
Yes it is quality....better than what is supplied in the kit.
14th May 2023 4:50pm |
I have posted an answer to your bearing fitting question, sorry if it's long winded |
14th May 2023 5:21pm |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 380 |
ah thanks for the warning ill get a 100mm made before I embark on this
25th Oct 2023 9:10pm |
The overall height including lid is 75mm and the outside diameter is 115mm the important internal diameter is 100mm so that is can accommodate the bearing that is being pushed out. |
25th Oct 2023 9:39pm |
