Home > Technical (L322) > Auto Wipers |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
The mirror would have fitted (in fact did ) but there was no mounting for the sensor on my old one and the black surround (kinda dotted painted onto the screen) did not have the big dip in it. I'll remove the lot and take photos for the wiki as it only took ten minutes to add it all together and wire it up.
24th May 2011 8:08pm |
The sensor mount is just a silicone pad. Needs to be heated to 60+ deg C with a heat gun and attached when new. The surround can be done by paint (saw this in a BMW forum where the sensor was retrofitted) or black adhesive foil (as I'm doing). Haven't got to fitting yet...
24th May 2011 8:29pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
HI, heres the mirror surround, sorry comport this is going to hurt under a tenner
24th May 2011 8:48pm |
I thought there was a special part of the screen that magnified the light/rain so the sensor picked it up easier..?
24th May 2011 8:50pm |
OUCH Dave - that shot went straight through my wallet..
24th May 2011 8:52pm |
Now I need the sensor - cheap as chips please lads! |
24th May 2011 8:58pm |
erm - no idea as I was at work. Left it wit SWMBO (big mistake). I phoned her when they had gone and asked if all was ok..? Her response.... I dunnow..!
dan.... what type of rain sensor have you got on your screen, is it got the two big cells or the 6/8 little ones V8 facelift Range Rover Autobiography 22" wheels.
24th May 2011 9:00pm |
mines got 6/8 if that's any help Dave...
hi yes so has my one but some come up with the 2 like matts
24th May 2011 9:04pm |
you can get the replacement pads here
24th May 2011 9:06pm |
From memory 4 I think? Two IR sendors Two recievers? |
24th May 2011 9:12pm |
so you will need to change your pad as well.. V8 facelift Range Rover Autobiography 22" wheels.
24th May 2011 9:24pm |
comport, did they fit new trim's with your screen V8 facelift Range Rover Autobiography 22" wheels.
24th May 2011 9:27pm |
