Home > Technical (L322) > Auto Wipers |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Not yet mate - Any tips, screws etc I need to look out for to remove the whole console or is it just pull down affair..? Ash
17th May 2011 6:47pm |
Follow up..
17th May 2011 8:08pm |
Got one off fleabay - £75 obviously not tried anything yet as I don't have the other parts (still to order) but do get the "dot of death" in the instrument cluster. Obviously inconsistent mileage I guess. Hopefully will be able to get that coded once it's all up and running though. Ash
17th May 2011 8:53pm |
Right - Light and rain sensor fitted to new screen. Looks great and lights up when I pull into the garage and turns off when I pull out (with a bit of a delay) but if I can get the auto wipers to work.
24th May 2011 6:42pm |
Until I had my issue with R/S I would say no. However In the last few days I found out that if your car is set to variable delay that is a specific setting. I'm working with Storey with his Rover All Comms to be able to code this. I would say that a dealer "should" be able to enable this for you, however I would definitely check to ensure they are comfortable/competent at this, I'd hope to pay no more than 30 mins labour? When Storey cracks the code for the RS then if I can help, I'll give you a shout. D |
24th May 2011 7:11pm |
Many thanks Dan - I can always rely on your knowledge to get me out of trouble. Much appreciated..
24th May 2011 7:15pm |
Actually - just sat here with the manual.... It suggests
24th May 2011 7:17pm |
Well, I hope my previous encouragement didn't get you into this trouble!
24th May 2011 7:20pm |
Yup - that's the "Speed Step" When you are stationary you get delay wiper on normal speed and slow wipe on fast speed |
24th May 2011 7:23pm |
Ah - That'll be it then. I was parked in the drive giving the car a quick shower at the time..
24th May 2011 7:34pm |
That's fine, take it all apart again!
24th May 2011 7:39pm |
24th May 2011 7:42pm |
Oh and be careful with the LCM. Mine said LCM - 4 on it but it did not work the auto features. The one I got from "the Bay" also said LCM - 4 and did work. This is what I bought in total.
24th May 2011 7:54pm |
Is there a different mount on the glass? ie did you "need" the new screen? |
24th May 2011 7:58pm |
