Home > Technical (L322) > Auto Wipers
Page 4 of 6 <123456>
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
The mirror would have fitted (in fact did Mr. Green ) but there was no mounting for the sensor on my old one and the black surround (kinda dotted painted onto the screen) did not have the big dip in it. I'll remove the lot and take photos for the wiki as it only took ten minutes to add it all together and wire it up.
If you already have either light or rain sensors then it should be fine as the screen will already have the mounting clips in place. I believe the rain /light sensor itself is the same size but contains both sensors in one unit. Ash
2016 SDV8 AB
Post #65633 24th May 2011 8:08pm
SteveMFr
Site Sponsor
The sensor mount is just a silicone pad. Needs to be heated to 60+ deg C with a heat gun and attached when new. The surround can be done by paint (saw this in a BMW forum where the sensor was retrofitted) or black adhesive foil (as I'm doing). Haven't got to fitting yet... Embarassed
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #65643 24th May 2011 8:29pm
daveo
HI, heres the mirror surround, sorry comport this is going to hurt Crying or Very sad under a tenner
http://cgi.ebay.co.uk/BMW-E39-E46-E38-REAR...3f075e83a0 V8 facelift Range Rover Autobiography 22" wheels.
Post #65645 24th May 2011 8:48pm
comports
I thought there was a special part of the screen that magnified the light/rain so the sensor picked it up easier..?
Before the new screen came I just fitted it all together and put a small bit of bubble wrap in behind the sensor (so it pushed up to the screen) when I fitted the mirror surround back in place. It did work anyway but assumed there would be more on the screen. Doh... Ash
2016 SDV8 AB
Post #65647 24th May 2011 8:50pm
comports
OUCH Dave - that shot went straight through my wallet.. Mr. Green
No worries mate - useful for others doing the upgrade though. Ash
2016 SDV8 AB
Post #65648 24th May 2011 8:52pm
daveo
you have your new screen fitted now, did they change the A piller and top trims V8 facelift Range Rover Autobiography 22" wheels.
Post #65650 24th May 2011 8:55pm
dan_uk_1984
Now I need the sensor - cheap as chips please lads!
Post #65651 24th May 2011 8:58pm
comports
erm - no idea as I was at work. Left it wit SWMBO (big mistake). I phoned her when they had gone and asked if all was ok..? Her response.... I dunnow..!
Will have a look tomorrow and if they haven't I'll be calling them back. How will I know if they did or not though? Ash
2016 SDV8 AB
Post #65652 24th May 2011 8:58pm
daveo
dan.... what type of rain sensor have you got on your screen, is it got the two big cells or the 6/8 little ones V8 facelift Range Rover Autobiography 22" wheels.
Post #65654 24th May 2011 9:00pm
comports
mines got 6/8 if that's any help Dave... Rolling with laughter
Dan - You can have mine for £55..? Wink Ash
2016 SDV8 AB
Post #65655 24th May 2011 9:00pm
daveo
hi yes so has my one but some come up with the 2 like matts
http://www.fullfatrr.com/forum/topic5964.html
he has posted some picks here at the above link...
the auto lights comes on the sensor with the 6/8 cells so if you have the other type you will need to change the mount... V8 facelift Range Rover Autobiography 22" wheels.
Post #65656 24th May 2011 9:04pm
daveo
you can get the replacement pads here
http://www.rejel.com/rejel-store/categoryi...10240.aspx V8 facelift Range Rover Autobiography 22" wheels.
Post #65658 24th May 2011 9:06pm
dan_uk_1984
From memory 4 I think? Two IR sendors Two recievers?
Post #65660 24th May 2011 9:12pm
daveo
so you will need to change your pad as well.. V8 facelift Range Rover Autobiography 22" wheels.
Post #65665 24th May 2011 9:24pm
daveo
comport, did they fit new trim's with your screen V8 facelift Range Rover Autobiography 22" wheels.
Post #65666 24th May 2011 9:27pm
