Home > Technical (L322) > drivers door not opening with key buttons after dead car bat
993porky
England 2004 Range Rover HSE Td6 Java Black
hi all
i have had a dead battery today so had to use key in lock to open drivers door to get to bonnet release catch,
after charging car battery im faced with prob when i use key fob to open all doors they open but not drivers i have to use key in lock, then when i press lock button next to hazard switch all lock except drivers an d the same when outside car use lock button on key fob all lock except drivers which needs key putting in lock to lock manually, any ideas anyone very frustrating Big Cry Range rover hse
Java black
Post #66092 27th May 2011 10:30pm
993porky
problem solved been talking to land rover technical bloke who told me once battery has been flat u sometimes get electrical glitches the trick is to disconnect battery again and leave for 10mins then re connect it restores everything,it worked for me everything back working on rangie now Thumbs Up Range rover hse
Java black
Post #66197 28th May 2011 11:21pm
