Home > My Range Rover > My 2005 4.2 Supercharged - here we go....
Page 3 of 7 <1234567>
Billie
England 2006 Range Rover Vogue 4.2 SC V8 Buckingham Blue
MOT
Just out of interest, our 2006 passed it's MOT yesterday. Monitor advisories....Sub-frame corroded but not seriously weakened (rear).
We like your welding and it looks like we will have to do the same soon. From new, £32K spent, about 2K pa. Crying or Very sad
Post #632132 18th May 2022 2:27pm
Superspoons
Handbrake
Handbrake
"Rear Parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (1.4.2 (a) (i))" ... was stated on the previous MOT back in November, so it was time to have a look at the Handbrake...
I was getting a squeak/squeal from the SC when slowing to a final stop. So, up on the jacks it went, wheels off and started to have a look.
Once the Calipers & Discs were removed it was pretty evident that the Handbrake Shoes had been Handbrake Shoes for too long... perhaps the originals at 81,000 miles ?
Borg and Beck kit had already been ordered from the excellent Advanced Factors so time to fit.
Before-
Parts-
Also ordered a new fitting kit
New versus Old-
Whilst in there I cleaned everything up and removed the rust off the inside of the discs & calipers. I removed and refitted the pads too and serviced the sliders in the calipers with fresh grease. The pads and discs are fairly recent with plenty of life left in them so no worries there. Pistons all good as were the seals. Just cleaned up the edge of the pistons to remove some light surface marks.
Worst part of the job was getting the top spring slotted into its hole. Its very tough so I sacrificed an very old long screwdriver and cut a slot in it with my Dremel. Using this I placed the spring in the slot and then pushed it over the hole whilst using another small screwdriver to push it home. Tough but this made it easier.
New shoes fitted:
Refitted discs, calipers/carriers and then adjusted up - took a little time but now have a rock solid handbrake on '4 clicks' of the handbrake instead of a very 'un-grippy' handbrake on '8 clicks'. If I'd had more time I would've painted the back plates but that can wait for now - I cleaned them and are in good condition. Gavin
Post #632615 23rd May 2022 7:29am
Superspoons
Reversing Camera
When I got the SC it had an additional camera fitted to the back alongside the dashcam mounted on the front windscreen. The original reversing camera didn't work anyway - it just showed a cloudy image on the screen. So it was time to remove the additional camera and look at fixing the existing one...
I stripped out the original ones - and now have a hole in the plastic cover so need a new one -
Removed the plastic covers.... the words 'crows nest' spring to mind -
Looking at the wiring and plugs - I haven't seen Scotch Locks since the days of my XR2 ! - I think I need the 'early type' camera sold by PowerfullUK. I also need the plastic cover around the camera as that is missing, unless it comes with the new one but they aren't in stock so I'm stumped for now.
I removed all the old wiring and generally tidied it up. Ebay / breakers will be my next stop I think... Gavin
Post #633213 30th May 2022 8:37am
Superspoons
Bluetooth Module
....Whilst in the boot I had a look at all the electrikary behind the panels and noticed this -
which was explained to me in this thread -
https://www.fullfatrr.com/forum/topic63621.html
So I removed it and opened it up with the aim of maybe cleaning it up and getting it to work -
But alas, after a good cleanup with Contact Cleaner it didn't work - no Bluetooth, All my cars entertainment stopped working when I plugged it in to, so I removed the MOST cable and after buying a proper plug on Amazon put it back to as it was so at least the head unit works.
Connector -
https://www.amazon.co.uk/gp/product/B09P2S...&psc=1
Proper Plug -
I start my search for a replacement, upgraded Bluetooth module by Ford as fitted to later Land Rovers... Gavin
Post #633484 1st Jun 2022 5:24pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
looking good nice job on the rust Thumbs Up
Post #633992 8th Jun 2022 7:25am
Superspoons
Thanks Thumbs Up
Work and Jubilee have got in the way but managed a couple of very small jobs lately....
Polished my tips!
Before:
After:
I used Wire Wool to gentle scrub the scum off with a little water to lubricate it. Then some fine Aerospace wool which has polish in it to buff them up - this was 'liberated' from Monarch Aircraft Engineering many, many moons ago.
....and added this which I found after I ordered it '3 L322's ago' Rolling Eyes
 Gavin
Post #634004 8th Jun 2022 9:19am
dhallworth
Polishing the exhaust tips makes a big difference to the appearance of the car IMO.
I always use Solvol AutoSol which brings them to a lovely finish.
Post #634025 8th Jun 2022 11:15am
Superspoons
It does David - I forgot to say I gave them a polish over with Autosol too Thumbs Up Gavin
Post #634036 8th Jun 2022 12:16pm
Nice thread, some good work going on there, you will have a very nice fatty when your done.... trouble is you are never "done" with a fatty, that's why we love them... Laughing
Keep the pics coming, everyone loves pics... Thumbs Up Pete
Post #634037 8th Jun 2022 12:18pm
Superspoons
Air Con Re Gas
Popped off to Kwik Fit for a pressure test (free) as my air con just wasn't really cold at all.
I've used this centre in Stevenage before for my last few L322's when it comes to Air Con and again I've had good friendly service.
No leaks following a long pressure test Thumbs Up so a refrigerant refill was carried out for £65. Ice Cold now so I'm happy - and cold.
 Gavin
Post #635276 23rd Jun 2022 11:53am
Superspoons
Auxiliary Fan Air Conditioning Flap Sensor - 0x30 error
After my recent issue with the suspension dropping, see here https://www.fullfatrr.com/forum/topic63860.html, ` I had the following fault reported -
HVAC-Heat / Cool
0x30 Air quality sensor line fault
After a search the issue is with the "Auxiliary Fan Air Conditioning Flap Sensor". A BMW part which fits E46, X5, E53, X3, E83, Z4, E85 Beemers. I purchased a second hand one from the Bay which was guaranteed for £18 -
https://www.ebay.co.uk/itm/175130593398
On the 4.2 SC it was an easy swap over. The clips at the bottom of the unit flex just enough to push up and pop the old unit out. Its located on the right hand side of the radiator, attached to the cowling -
just pull it out, swap the connector over, give it a squirt of contact cleaner and your done -
Plugged in the IID Tool, rescanned and viola, code gone. Not sure I'll notice anything different to be honest but its one less code and satisfies my code OCD Very Happy
Next is to look into that hole in the cowling with the red wire - looks like a broken plastic holder or something. Gavin
Post #635636 28th Jun 2022 10:41am
dhallworth
That's interesting to see where that box should be mounted to as mine was tucked up behind the power steering reservoir when I got the car and I've never really spent much time looking to see where it goes!
Once the fan cowl goes back in I can reattach it properly now Very Happy
Post #635638 28th Jun 2022 11:06am
Superspoons
Glad it helps David Thumbs Up
I wanted to know exactly what it did... so after a bit of Googling ... it appears its pretty important to stop overheating if the fan doesn't come on and the car's stationary ... Shocked
Automatic recirculated air control (AUC) is an additional feature controlling the automatic operation of recirculated air. The AUC feature uses an oxidizable gas sensor usually mounted behind the right side of the radiator or the right side upper portion of the fan shroud (samples air quality as coolant fan pulls across the radiator). The AUC sensor contains a combined heating element (powered by the IHKA module) and a gas sensor. The gas sensor requires heating to work efficiently. The sensor produces a varying voltage based on air quality (concentration of hydrocarbons, NOX, SOX, and CO). The voltage increases as the air becomes more polluted. After it reaches a preset value, the IHKA closes the fresh air flaps. To prevent glass fogging, the system has built-in time limits: 3 minutes when heating and 12 minutes when cooling. With normal air quality, the AUC sensor reads about 0.5V. If the AUC sensor voltage increases to 3.0V, the ventilation or fresh air flaps will close (0%). At about 2.5V, the fresh flaps will read about 20% and 100% (fully open) at 2.4V.
I know its a Beemer but its applicable to a L322
https://www.youtube.com/watch?v=qe5eqRQpw04 Gavin
Post #635640 28th Jun 2022 11:13am
dhallworth
Interesting! Thanks Gavin. Thumbs Up 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #635645 28th Jun 2022 1:12pm
Superspoons
Rear Camera
So, after unearthing a sea of wires and scotch locks a few months ago I decided I'd bite the bullet and buy a new reversing camera from PowerfulUK. My L322 needed the earlier one so I placed an order on Wednesday morning and it arrived via DHL Thursday lunchtime.
https://www.powerfuluk.com/vehicles/range-...-type.html
There's plenty of videos out there as to how to get the old camera out but basically its -
    1) Remove Plastic Cover over the rear window motor
    2) Unplug the connectors for the camera and spoiler brake light
    3) Undo the three 8mm bolts holding the spoiler in place and slide it towards the back then lift off
    4) Remove the old camera & cables
    5) Fit the new one and route the cables
    6) Place the spoiler back on the tailgate and secure the grommets
    7) Connect the Brake light and Camera connectors up
    8 Screw it back down with the 8mm bolts
    9) Replace the plastic cover
Took about 30mins and very pleased with the camera quality and picture.
Original Camera - cover missing an no picture from it -
 Gavin
Post #636258 7th Jul 2022 5:00pm
